  • June 19, 2025, 09:11:12 AM
Author Topic: Painting Ultracote  (Read 1366 times)
Offline Roy Heitmann
Painting Ultracote
« on: October 08, 2017, 03:36:19 AM »
Anyone out there who knows if UltraCote can be painted? If so, any requirements for type of paint?
Online Perry Rose
Re: Painting Ultracote
« Reply #1 on: October 08, 2017, 05:08:20 AM »
Yes it can. I use Rustoleum 2X spray cans. No special prep just a good cleaning.
Offline fred cesquim
    • Fred Cesquim Aeromodelos
« Reply #2 on: October 08, 2017, 07:47:45 AM »
I paint all of my ultracoted (or monokoted) wings/stab
i sand with 800/1000 grit sandpaper, spray with auto lacquer or polyester and clear coat everything.
but i still paint fuselage in a traditional way
on the first plane the ultracote is white, everything else painted
second plane is red monokote and trim painted
« Reply #3 on: October 08, 2017, 08:34:18 AM »
Fred,
Ohhhhhh my gosh!
You are the master Guru.  H^^
Charles
« Reply #4 on: October 08, 2017, 12:08:43 PM »
Thanks. Gave me a rest to how to proceed. I wanted a seamless transition between the painted fuse and Ultracoteed wing/stab/rudder. Always used Polyspan on my wings before, but for my Trivial Persuit I'm going to try the Ultracover.
« Reply #5 on: October 09, 2017, 05:36:33 AM »
Fred,
Ohhhhhh my gosh!
Charles
thanks Charles.
i am not a guru, but i like to use this method! i believe i nailed it.
regards from Brazil
« Reply #6 on: October 09, 2017, 05:41:52 AM »
i have tried 2 methods:
masked wing/stab 1/2" over the sheeting and primed the fuselage up to the masking tape, then monokoted over that 1/2 lip very close to the fuselage.
either ordered matched lacquer colors to the monokote and painted a lip of 1/4 over the monokote, or painted the fuselage color and designed to advance over the wings to seal the gap and made a good color match.
the other method was discarded later: monokoted first and then primed the fuselage over the monokote lip, but this lead to a "bridge" hard to get rid of later.
either way will work fine
Online Perry Rose
« Reply #7 on: October 09, 2017, 06:16:40 AM »
The only problem is that you can't apply masking tape or any tape on the painted areas. It may well pull the paint off. And the directions say it takes 7 days for the paint to cure when painting  plastic. It will dry normally but not completely cure for 7 days.
« Reply #8 on: October 09, 2017, 10:46:21 AM »
Now you tell me! D>K
« Reply #9 on: October 09, 2017, 02:32:06 PM »
not at all, the white is painted and the black checker too. i have sanded with 800 grit sandpaper the blue ultracote, sprayed the white and after 2 days, applyed the black. just need to be really carefull unmasking and using low tack vinyl mask
