General control line discussion => Open Forum => Topic started by: bob branch on August 14, 2006, 07:17:27 PM
I have read on occasion that some people cover their planes with films (eg monocoat/ultracoat) and then paint them. What kind of paints work? Will dope work? What happens when you have to reshrink out a wrinkle later after its all done?
bob branch
Bob,
Top Flite LusterKote is supposed to work over most surfaces. They have a few pages on how to use it here:
http://www.monokote.com/lustrekote/painting-tips/topr7200tip1.html
I used to use a clear film called Seal-Lamin. It is a frosted looking clear 'til you apply heat. I used Pactra AeroGloss thirty years ago and it is still on the Seal Lamin.
In answer to your last question, it would probably look like a painted wrinkle. ;D
Seriously though, get the wrinkles out first. You knew that though dincha? **)
Tom
Getting the wrinkles out first isn't a problem. However, every covering job no mater how good develops wrinkles over time, especially if out in the sun or on a warm day. I've been in RC for 3 years now and have had experience with virtually every film there is. They all do it. Its why I would not use the system in CL stunt. The question is actually for an RC application. Interesting though your sucess with a dope years later. Cudos!
bob branch
Bob,
I thought you were speaking about some wrinkles along some of the more dificult areas on the wing tips or other problem areas when covering. I have no experience with the slack wrinkles from the sun. I would hope that the paint would be ok after re shrinking, but dont know. I used the Seal-Lamin #^on my combat planes because it didn't wrinkle from being in the sun. The dope sticking after all those years in the attic suprised me. I just covered the wing tips and elevator for some reference while manuvering. :D
