Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
June 19, 2025, 06:15:14 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Open Forum
(Moderators:
RandySmith
Steve Berry
Compressor Valves
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Compressor Valves (Read 725 times)
Motorman
Trade Count:
0
Admiral
Compressor Valves
on:
August 23, 2020, 10:55:56 PM »
blank
Last Edit: August 21, 2021, 11:50:53 AM by Motorman
Logged
Lyle Spiegel
25 supporter
Trade Count:
0
Captain
Welcome to the Stunt Hanger.
Re: Compressor Valves
Reply #1 on:
August 24, 2020, 05:58:14 AM »
If the CF is anything like CF used for tuned pipes, it should be ok in the compressor. I dont know how hot the tune pipe runs, but likely higher than the compressor.
Logged
Lyle Spiegel AMA 19775
Will Hinton
25 supporter
Trade Count:
0
Admiral
Reply #2 on:
August 24, 2020, 10:54:34 AM »
It's not really the CF that determines the heat tolerance, but what epoxy was used to bond it. The cf pipes use an epoxy that is post cured to around 400 degrees in two or three steps.
Logged
John 5:24
www.fcmodelers.com
kevin king
25 supporter
Trade Count:
0
Admiral
Reply #3 on:
August 24, 2020, 09:03:02 PM »
Tuned pipe on an air compressor...cool!
Logged
Robert Whitley
21 supporter
Trade Count:
0
Commander
Reply #4 on:
August 24, 2020, 09:36:37 PM »
In case that doesn’t hold up many years ago I had a similar situation and used a piece of metal pallet banding material. It lasted the life of the compressor which was about twenty or so years. I would hope carbon fibre would hold up at least as long.
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Open Forum
(Moderators:
RandySmith
Steve Berry
Compressor Valves
