  • June 16, 2025, 01:11:53 PM
Author Topic: Cold Cold and more Cold  (Read 11137 times)
« on: February 19, 2006, 11:58:24 AM »
Well the weather has been below freezing. I took a space heater in the garage so I could spot paint a few places on the Twister. I hope to finish it tomorrow.
The one good thing about the cold weather is Zuriel has loaned me some of Windy's tapes. Man are these tapes good. Next best thing to being there. Building of Miss Ashley.
I will post some pictures if I ever getter dunn.
Robert nice clean site...... no one throwing rocks over here.
« Last Edit: February 19, 2006, 04:15:46 PM by RootBeard »
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
Re: Cold Cold and more Cold
« Reply #1 on: February 19, 2006, 03:30:27 PM »
Below freezing...I'd be happy to just get above zero.
--Ray
--Ray
AMA902472
Offline Scott Jenkins
« Reply #2 on: February 20, 2006, 07:04:30 AM »
Cold you betcha, it got down to 55 last night had to put on long pants, oh well today the high is in the upper seventies may have to turn on the a/c at work  ;D  ;D  ;D
Scott Jenkins
Zellwood Fl.
AMA 43122
Scott Jenkins
AMA 43122
FAI F2C VOLUME 2 SECTION 4, 4.3.7
m) During the refuelling and the restart of the motor, and until the time when he releases the model aircraft, the mechanic must keep the model aircraft in contact with the ground by at least one point and with the centre line outside the flight circle. During that time the pilot must be crouching or sitting inside the centre circle. He keeps one hand on the ground and his handle and his lines as close to the ground as defined by the F2C panel of judges until the model aircraft starts again.
Online RC Storick
« Reply #3 on: February 20, 2006, 07:11:32 AM »
Yea the weather there is OK now but wait till summer! The bugs are unbearable! MUCHO BUGS!!
« Reply #4 on: February 20, 2006, 11:53:07 AM »
Just wet and cold here. 34 degrees, about 95% humidity. Great time to be painting a plane.
« Reply #5 on: February 20, 2006, 03:49:07 PM »
Bugs bad in the summer no way we just super glue them to the indoor planes for propulison way cheaper than rubber bands. Besides if you eat enough garlic then bugs are are not the only thing that won't bother you.  ;D
Scott
Scott Jenkins
AMA 43122
