  • July 17, 2025, 05:38:44 AM
Author Topic: Pagin' Leester!  (Read 1122 times)
Pagin' Leester!
« on: October 12, 2006, 03:41:29 PM »
I saw in another thread where you put three flights on the F-94...........
How did we miss the flight report???????   <=
Bill <><
Offline Leester
Re: Pagin' Leester!
« Reply #1 on: October 12, 2006, 05:03:03 PM »
Sorry Bill: I guess I'm shirking my duties.
  I did fly it Tuesday, I didn't do much other than go in a circle but it flew fine just need to trim it out. It was a little light on the lines 60' eye to eye .015's. I have no rudder or engine off set, I just have the fin and rudder in line but angled a little to the outside and tappered on the inboard side. I did run the B-25 rich being it's first flight, I'll lean it a little at a time and see whats up. I'm using a 9-4 Top Flight but have a 9-4 and 9-6 APC on the way also. Being a little porky at 32oz I just need more speed and it should be fine. Like I said it flew fine, straight and no hunting. I do have adj. lead outs so when I'm not pressed by threatening rain and wind I should get it worked out.
Leester
ama 830538
Re: Pagin' Leester!
« Reply #2 on: October 13, 2006, 07:43:08 AM »
Leester, you might also consider the Top Flite Power Point 10-4 Prop.  That is what I have on the Mauler that Emmy flew.   DOC Holliday
Offline Leester
Re: Pagin' Leester!
« Reply #3 on: October 14, 2006, 03:11:38 PM »
Doc: Thanks I forgot about the 10-4 you mentioned on OCL, I've got some and will put in my flight box.
Leester
ama 830538
