General control line discussion => Open Forum => Topic started by: Bill Little on October 12, 2006, 03:41:29 PM
I saw in another thread where you put three flights on the F-94...........
How did we miss the flight report??????? <=
Bill <><
Sorry Bill: I guess I'm shirking my duties.
I did fly it Tuesday, I didn't do much other than go in a circle but it flew fine just need to trim it out. It was a little light on the lines 60' eye to eye .015's. I have no rudder or engine off set, I just have the fin and rudder in line but angled a little to the outside and tappered on the inboard side. I did run the B-25 rich being it's first flight, I'll lean it a little at a time and see whats up. I'm using a 9-4 Top Flight but have a 9-4 and 9-6 APC on the way also. Being a little porky at 32oz I just need more speed and it should be fine. Like I said it flew fine, straight and no hunting. I do have adj. lead outs so when I'm not pressed by threatening rain and wind I should get it worked out.
Leester, you might also consider the Top Flite Power Point 10-4 Prop. That is what I have on the Mauler that Emmy flew. DOC Holliday
Doc: Thanks I forgot about the 10-4 you mentioned on OCL, I've got some and will put in my flight box.
