  • June 17, 2025, 10:39:36 PM
Author Topic: David Riggs makes Walker/Eather pitch gauge  (Read 3688 times)
Offline Bradley Walker
    • The Urban Rifleman
« on: August 03, 2016, 11:07:56 AM »
JUST WOW!!
-George Bernard Shaw
Re: David Riggs makes Walker/Eather pitch gauge
« Reply #1 on: August 03, 2016, 11:21:15 AM »
A real work of art!
« Reply #2 on: August 03, 2016, 11:30:08 AM »
Online Motorman
« Reply #3 on: August 03, 2016, 11:48:07 AM »
Once again the lock in feature totally unnecessary adds to the expense, adds to the weight and slows down pitch work. Prather got it right with just a simple straight slot.
« Reply #4 on: August 03, 2016, 11:56:34 AM »
Actually Prather  did  not get it right, many of the Prather gauges rock, this makes it very difficult to read , when the mount rocks side to side, even a tiny amount, its makes reading and setting pitch near impossible, the fix was to make the prop mount piece wider on both sides so it cover the milled slots on both sides.
This part is way better and way more stable than the stock unit, We made these from aluminum and delrin, both worked perfectly
Re:
« Reply #5 on: August 03, 2016, 12:08:05 PM »
Motorman, you have no idea what you are talking about.   And I have no idea why you insist on bashing something you have nothing at all to do with!!!!  Why don't you just go comment on someone elses thread.
Sent from my SM-G920T using Tapatalk
Offline Doug Moon
« Reply #6 on: August 03, 2016, 12:37:38 PM »
My Prathers, yes I have two, rock back and forth as Randy describes terribly! I have to hold it just right to get the same reading on each side. It is a pain in the ass. And the two don't read the same prop the same. Luckily it's only used as a way to monitor changes made. The actual pitch means little it's the amount you change it and which way that matters. But with a gauge that is made with a slider like this and the reading gauge properly set on each and every one you could read prop to prop comparisons across the net and makes changes accordingly.
Doug Moon
AMA 496454
Dougmoon12@yahoo.com
Offline bill bischoff
« Reply #7 on: August 03, 2016, 12:53:03 PM »
Jim Lee sells a replacement slider for the Prather that is wider and works better.
BB
Re:
« Reply #8 on: August 03, 2016, 01:07:52 PM »
My prototype gas the t slot and I really like it.   It doesn't move at all.
« Reply #9 on: August 03, 2016, 01:14:15 PM »
And the price?     H^^
Offline Jim Hoffman
« Reply #10 on: August 03, 2016, 02:24:40 PM »
Hi Doc,
I know Dave well, and suspect this is a one of a kind item for his personal use.  I do not believe it is being offered for sale.
Jim Hoffman
« Reply #11 on: August 03, 2016, 02:42:33 PM »
It was indeed made for personal use.
« Reply #12 on: August 03, 2016, 02:46:39 PM »
David  and Brad that is  really nice  work !
Online Brent Williams
« Reply #13 on: August 03, 2016, 02:59:38 PM »
Very nice work.
I feel my covet impulse being triggered.
Availability? Group purchase?
« Reply #14 on: August 03, 2016, 04:09:13 PM »
I have no idea why I couldn't have a run made...  I mean.
« Reply #15 on: August 03, 2016, 04:13:14 PM »
BB
Yeah, I've had one of Jim's replacement sliders for several years and it does indeed make a vast improvement in using the Prather gage.
« Reply #16 on: August 03, 2016, 06:34:51 PM »
This is the type of equipment I need for where I'm going. If your going to invest in Randy Smith custom motors, you need to have those competition props dialed in!!
Too bad they can't make more. But from the looks of it, this sure can't be easy to do.
