  • July 03, 2025, 12:05:29 AM
Author Topic: PA .40 Ultra Lite  (Read 1395 times)
Offline Larry Fernandez
PA .40 Ultra Lite
« on: January 19, 2018, 10:30:29 AM »
A couple of questions for you guys.
How much does the PA .40 Ultra Lite weigh?
How much does the Ro Jett .40 weigh? ( we’re talking rear exhaust here)
And now for the sixty thousand dollar question.
Do anyone of you happen to have a PA .40 Ultra Lite you would be willing to part with?
Larry, Buttafucco Stunt Team
Online Jim Hoffman
Re: PA .40 Ultra Lite
« Reply #1 on: January 19, 2018, 12:17:29 PM »
My PA 40 Lite (RE) weighs 8.3 oz.
header pipe was 1.0 oz.
I used the header pipe for a muffler
Sorry it is not for sale
« Reply #2 on: January 19, 2018, 12:47:32 PM »
Hi Larry,
The RO Jett 40 BSERE (Bar Stock, Rear Exhaust) weighs 8.6 oz on my scale. (I have two of them).
With the header pipe installed it weighs 9.3 oz.
With the header muffler installed it weighs 9.5 oz.
I don't really know how it compares to the PA Ultra Lite but the RO Jett 40 BSERE is a very good running engine and easy to use!  I also have one of the Side exhaust versions and flew it in a Geiseke Nobler for a while and it was a great combo.
I haven't run one on a pipe yet!  Soon I hope!  Dee Rice had one running on a pipe several years ago at VSC and it was impressive.
The SE engine also weighs 8.6 oz but the tube muffler supplied with it brings the weight up to 9.7 oz
« Last Edit: January 19, 2018, 08:59:25 PM by Randy Cuberly »
Offline JackComer
« Reply #3 on: January 19, 2018, 12:53:29 PM »
Larry
  Sent you a PM
Jack
Jack Comer
AMA 129715
« Reply #4 on: January 19, 2018, 04:03:50 PM »
Larry
  Sent you a PM
Jack
Jack, I want the motor.
Give me a call, (408) 227-1693
« Reply #5 on: January 19, 2018, 05:31:57 PM »
Hi Larry  the  UL Merlin 40  weighs  8.2  ounces, if you find one  I do have the parts to rebuild a  used one  if  needed
« Reply #6 on: January 19, 2018, 06:51:51 PM »
Thanks Randy,
I just got off the phone with Jack Comer. He’s boxing one up as I write this.
It’s only been run a few times on the bench so it shouldn’t need rebuilding for a while.
I do need to talk to you about a header and pipe as well as advice on prop and fuel tank size.
I’ll call you Monday
Thanks again Randy
And thank you Jack
Larry Buttafucco Stunt
Offline Mike Scholtes
« Reply #7 on: January 19, 2018, 07:55:40 PM »
Hi Larry:
I have a PA40UL on pipe with a Randy Smith header in my Oriental Plus, and have some info on tanks, props etc. Larry Wong also has one in his full-fuse Imitation on pipe. These are some local ones you could have a look at if you can trudge up to Alameda some Sunday. Larry has a lot more experience with the motor than I do. BTW mine started literally on the first flip when beginning break-in, and then about 20 more first-flip starts to get about 2 hours on it on the bench.
