General control line discussion => Open Forum => Topic started by: Motorman on June 23, 2024, 04:01:22 PM
Please school me on PA 40's. I think they made a big case and light case version? Is one version call the Merlin? Are some abc, is there side and rear exhaust? Can you use a muffler or need a pipe? Does it make more power than LA46?
MM 8)
There are (were) two of them - the PA40 (regular case) and PA40UL (ultralight). The original PA40 used the same case as the other Nelson engines at the time, I think the same as the pylon engine, and then later used for the 51, 61. and 65, essentially compatible with the 40/46VF, each other, and the RO-Jetts, with minor tweaks required to fit any of them interchangeably. There were/are side exhaust and rear exhaust versions (side using the combat case, I think).
The 40UL is smaller all around and somewhat lighter. I think it is about the same as the Aerotiger 36 but I am not sure. They run almost exactly like the original 40 as far as I can tell. I have only seen rear-exhaust versions, use the Aerotiger for side-exhaust.
All of them are AAC, as far as I know.
Any of the will run on a muffler, presumably, although I can't say I have seen anyone do that. The timing is the classic hard-breaking 136 degree exhaust duration. I only ever ran the original and piped, of course, since that is the way it is competitive.
Set up properly (as it can be, see below...) it is a vastly more effective stunt powerplant than a 46LA, this is a real competition engine and has had a NATS win and numerous high finishes. It is a vast upgrade over 4-2 break engines and muffler sport engines like the 46LA.
Having said all that, and despite Paul Walker having won the 94 NATs with it (which I note is **30 years ago**), I found it to be extremely fussy and hard to get set correctly to have decent power without explosive 4-2 breaks. I *sort of* got it OK in the Midwest in the humidity and elevation, but it was one of the most difficult engines we ever tried in terms of excess power boosts. You could tame it, but then it had a lot less power than the obvious alternatives. Paul and I, completely independently, gave up on it at about the same time, for the same reasons, and went back to the 40VF - which was like magic and ridiculously easy to fly by comparison. It was difficult in exactly the way Kafin was talking about, the breaks were far, far, too aggressive and powerful ,and you didn't have enough power to run it in a 4 all the time. I eventually got an OK system by pulling the pipe way out, and running 3 1/4 pitch, launching at 12,000+. Then I went to Muncie and it was absolutely hopeless.
The early marks of the PA61 has the same sort of issues but was so much more powerful that you could run it in a 4-stroke all the time and at least with the spigot venturi, avoid the break most of the time. Someone came up to me at the 2002 NATs and congratulated me on how well my Saito was running! Nope, PA61 pumped to the gills and thundering around in a constant 4. Later marks of the 61/65 made some internal changes that reduced the problem. Ted and I run RO-Jett 61s precisely because it *doesn't* to this, ever, in any conditions, and can run very nicely across the break, smooth as silk - like a giant 46VF.
If you have a PA40, just use it. If it is an Ultralight, PM or contact Michael Scholtes, his ran absolutely great, even 5 feet above sea level and 45 degrees F. If you don't, then I would instead suggest you will have a lot easier life if you find someone with a 40VF, 46VF, PA51, etc. Everyone has all these and they are just rusting in drawers since they have been supplanted by PA61/65/75, Jett 61, and much more so, electric.
p.s. I note that if you looking for an alternative, Randy sells (sold?) AAC cylinder/piston assemblies for the 40 and 46VF, which saves some weight, which is the only legitimate beef anyone ever had with the VF.
Great information, really appreciate it.
MM 8)
[/quote
Most of what brett wrote above is wrong, no combat case was ever used , all were very easy too run, as long as you did not drill out venturies use high nitro fuel and did not remove the head shims, i run oone for 8 or 9 years at the NATs and for 9 years of regular contest seasons , as did many others . the first engines came in SE or RE versions , all PAs are AAC the later MERLIN series is only rear exhaust Many wins at the NATs for the 40s both open and classic Jim Lynch won 2 times with the 40 , their first year out all PA 40s at the Texas NATs finished in the finals and won that NATs. All 40s are very tailorable to a very mild 4-2 or a mid or much stronger 4-2 .they also are great engine and run very well on a pipe or mufflers , all have mild crank timing and sleeve port timing is milder than a ST46. use common sense a resist trying to force the engine to only run 1 predetermined prop , only high nitro fuel or remove the head shim. you will have much better results
if you want any more info please ask
regards
I ran the PA 40 for about 3 years. It was on a slightly heavy airplane, so I had to get my rpm correct every time, but the engine was never a problem to set or maintain. No modifications are needed. It is far superior to the VF 40 and 46.
David and I recently ran a test on the PA 75. I told David that I could throw a bunch of random parts together, and develop a run that would be at least as good as his. Development required 1 flight. The first prop, pipe, and fuel I grabbed was what I used. David brought all the parts to make "his" modifications to the 75 run, and I gave him permission to make any changes he wanted (as long as they were reversible) but oddly enough, he chose to use my setup for the 4 days we flew together. The only change he made was to his Eather prop. I preferred my Bolly over his Eather prop, but both ran well with zero modifications to the engine.
Just sayin....
Derek
