  • June 21, 2025, 06:19:21 AM
Author Topic: CG on a Ringmaster Jr.?(Roger)  (Read 1538 times)
Offline Phil Coopy
« on: October 06, 2006, 05:05:47 PM »
Fixin' up a Ringmaster Jr. for a buddy but I don't have plans.  Were should the CG be?
Phil
« Last Edit: October 07, 2006, 08:11:42 AM by PHIL COOPY »
Offline Roger Vizioli
  • CLiner
Re: CG on a Ringmaster Jr.?
« Reply #1 on: October 06, 2006, 07:27:41 PM »
Phil,
If this is the RM jr for a .19, 34" span, 19 3/8" long.
Plans show a cg range from the front of the 3/16" sq spar doubler to the rear of the 3/16" spar.
ie cg range is 3/8"
send note if you need more/clearer info.
Roger
Roger Vizioli
AMA L-2408
Florida/Space Coast
Offline Phil Coopy
« Reply #2 on: October 07, 2006, 08:05:47 AM »
Roger, I don't have the plans and the wing is covered with $kote so I can't tell where the doubler is.  Can you give it to me in terms of distance from the LE?
Thanx, Phil
  • CLiner
Re: CG on a Ringmaster Jr.?( Phil)
« Reply #3 on: October 07, 2006, 07:28:27 PM »
Phil.
Sorry for late reply.
Fore/aft cg range, measured from the leading edge of wing is as follows:
Most Fwd position: 1 11/16" aft of leading edge
Most rearward position: 2 1/16" aft of leading edge
Check your e-mail for two photo's from the plans I have.
Hope this answers your question.
Roger
Roger Vizioli
AMA L-2408
Florida/Space Coast
