  • July 13, 2025, 09:01:15 PM
Author Topic: Over Runs  (Read 3789 times)
Offline John Rist
Over Runs
« on: September 10, 2015, 08:15:57 PM »
At our last club meeting the subject of over-runs cam up.  Ty pointed out that 2.4 radio engine cutoff was legal.   As I read the AMA rules it is indeed legal for retracts and engine cutoff.  Looking into the hardware available it would not be that hard to set up.  My question is anybody using a 2.4ghz setup to prevent over-runs?
Re: Over Runs
« Reply #1 on: September 10, 2015, 08:37:47 PM »
  I am not aware of any of the usual suspects using it for either cut-off or landing gear. It's not a critical issue because with 8 minutes, it's pretty easy to make the limit without a radio cutoff. And, it's only been unambiguously legal since January.
Re: Over Runs
« Reply #2 on: September 10, 2015, 09:43:09 PM »
  I made up a "throttle pack" for my new profile "Dusty" so I could fly it in profile scale contests. I used a small Spektrum reciever, a really small servo, and a 7.4 volt, 250mah battery pack controlled with a dummy plug. It all fits in a small box that attaches to the side of the fuselage with 4 screws, and connects to the throttle with a simple wire pushrod. The whole throttle pack only weighs aboput 1.5 ounces. I hang the transmitter from a clip on my belt to work the throttle. I never intended to fly it this way in contests, the R/C carb is too flakey. If I fly stunt with it, I remove the throttle pack, replace the carb with a venturi and needle valve and fly as usual. So it can easily be done at that kind of weight pretty easily. I think the thing to do if you must try a fuel cutoff, is to adapt the device that some F/F guys use on F/F models. It's a hand held single channel device with a button. Weighs only a few grams. My son Sean uses one on his discuss launched glider for dethermalizer. Great for small fields and trim flight. The same device could be rigged up on a fuel cut off on a stunt model at very small weight penalty. But in my opinion it is one more thing that can go wrong at the wrong place of a critical maneuver if accidentally triggered!  Much more traumatic than an over run!
Offline Mike Scholtes
Re: Over Runs
« Reply #3 on: September 10, 2015, 09:56:56 PM »
The RC setup would only need to trigger a Free-Flight-type pinch-off valve, no RC carb needed. Or, use a new FF electronic timer to trigger the shut-off device, as modern FF models are now mostly using. That would eliminate the RC stuff entirely. See Texas Timers web site, or Star Link web site, for details. They weigh only a few grams and are easy to program in the field.
Or, as Brett notes, just figure out how much fuel to put in the tank based on experience with temperature, altitude, nitro content, etc. With the 8-minute AMA rule there is no reason for an over-run, and it peeves the judges to stand there watching while you do an extra 30 laps until fuel exhaustion.
Offline Jared Hays
Re: Over Runs
« Reply #4 on: September 10, 2015, 10:14:10 PM »
Is it really that hard to pull fuel out of your tank?  Why add weight with batteries and radio gear for a cutoff.  I just got back from Denver 5500 feet altitude to where I normally fly 1000 feet altitude.   Only took me 1 flight on each plane to know how much fuel to pull out to compensate for the altitude difference which makes your engines run longer on the same amount of fuel.
Re: Over Runs
« Reply #5 on: September 10, 2015, 10:37:33 PM »
  In my case I pretty much always extract the same amount of fuel, even for FAI. It's not always the same type of fuel, however. If you adjust the nitro to get the same power, you get about the same run run time. I checked my indicated flight times at the last TT I went to and I was between 6:20 and 6:35 for all of the flights.
   What *is* critical is to get a tank that cuts off reliably with almost no warning. It has to run through the 4-leaf with little or no leaning out, and then cut off a few laps later. I use the high-circling-flight cutoff that I learned from Whitely, unless it is really windy, in which case I revert to the cutoff loop. The overhead flight allows you to dive to get speed for landing.  The windy day at the NATs this year, I did my first cutoff loops in about 5 years. You start a little *before* dead-downwind (reverse-bias), allow it to whip up, and then again get a bunch of speed built to be able to reliably control it through the upwind section of the last lap. I probably exited on my second flight at about 85 mph with the engine quit, and then it's easy to get on the ground 45 prior to dead downwind at relatively high speed.
   If you just fly around level and wait, you have no control over the landing position. If it's windy and it cuts off around dead downwind or sometime in the next 90 degrees in level flight, you are going to be super-screwed.
Offline Ward Van Duzer
Re: Over Runs
« Reply #6 on: September 11, 2015, 09:34:36 AM »
"Super-Screwed"!
Great phrase Brett!
Ward
Offline Gary Mondry
Re: Over Runs
« Reply #7 on: September 11, 2015, 10:58:07 AM »
I clearly fall into the "super screwed" category as I simply fly around level and wait (and hope).  So what is it that allows a cutoff loop to work?  Is the tank vented a particular way or is it dependent on some maximum amount of remaining fuel?
AMA 10663
Re: Over Runs
« Reply #8 on: September 11, 2015, 11:24:55 AM »
   The acceleration of the loop (or high circling flight) pulls the fuel towards the bottom of the tank, and away from the pickup. Note that it works better on insides than on outsides, analysis is left to the reader.
   The key to being able to get it to fly through the 4-leaf at low fuel is to have the correct wedge angle. A Veco T-21 worked OK when you couldn't corner to hard, but you generally need it to be a bit steeper nowadays. Canting or tapering the tank in plan form also helps.
Offline Gary Mondry
Re: Over Runs
« Reply #9 on: September 11, 2015, 11:40:06 AM »
Well, that makes sense, but won't help me much with my Hayes clunk tanks...
AMA 10663
Re: Over Runs
« Reply #10 on: September 11, 2015, 12:25:11 PM »
Nope.  Get out the soldering iron Gary.  Clunks don't work well in this.  You DON'T want a clunk following the fuel around.  You may still have to pull some amount of fuel out to get the fuel level low enough for a good cutoff.  Usually you'll need to hear the engine starting to go into its leaner almost- out sound before the loop is a sure bet.  You may need to extract some fuel to find that place a few laps after the clover.  The loop simply pre-emps the several more laps of burp-scream-burp.  As Brett was talking about,  not enough slope angle in the tank wedge makes that a harder guess and the plane may think the first turn in the clover is your cutoff loop.  Ask me how I know.  The clunk has to go!
Offline John Rist
Re: Over Runs
« Reply #11 on: September 11, 2015, 03:21:20 PM »
Reading all of the posts I am hearing words that indicate that a predictable cutoff would be a good thing.  Nothing is fool proof so if you add cutoff electronics it could inadvertently kill the engine at the wrong time.  However running short on fuel and have it die in the clover is not a good thing. Also  a well designed system most of the failure modes should leave the engine running not kill it unannounced.
I am just beginning to look at a possible solution, But my first thought is that the battery could replace part of the tip weight.  The transmitter could be mounted on your belt.  The weight gain could be close to zero.
Another advantage would be the ability to abort a bad engine run eliminating  the need to fly in circles for 5-10 minutes.  It could also be used to save an engine from a lean run.
Additionally the top pilots don't need or want a cutoff.   Through hard work, at our hobby,  they have it down pat.  The rest of us need help.
PS if and when I do decide to try a stunt contest I will probably fly an electric which, by design, will have an electronic timer.
Re: Over Runs
« Reply #12 on: September 11, 2015, 03:39:55 PM »
I've been using clunk tanks for some years and haven't had any significant problems with run-time. The key thing is to get some practice flights in and treat them just like a contest flight. I don't often time my flight times, but I can certainly tell that it's running too long, so I adjust from there.
The "mustard pump" is my favorite way to fuel up. Each full stroke (after purging the pump of air) gives EXACTLY one ounce of fuel into the tank. With my current plane (piped .46VF), I run 5.5 to 6 oz of 10% nitro. I can adjust the flight time by adjusting the amount of oil in the fuel (more oil = shorter run), increase the prop load (more prop = shorter run), increase the nitro content, or reduce the fuel load. Reducing the fuel load is easy enough. I'm planning to make a spacer thing with a handle that will limit the fuel delivered on the last stroke of the pump...1/4 oz increments, I hope. Good enough!   H^^ Steve
Offline Target
  • C/L Addict
Re: Over Runs
« Reply #13 on: September 11, 2015, 04:20:38 PM »
Yep, certainly flying an electric stunter with a timer is simplest.
But I find all the glow fuel info fascinating none the less.
Hence my subscription to this thread.
Chris
AMA 5956
Re: Over Runs
« Reply #14 on: September 11, 2015, 04:29:34 PM »
  I haven't figured out how to make the electric cut off when I want WRT the wind, without 2.4 gHz, anyway.
Re: Over Runs
« Reply #15 on: September 11, 2015, 04:32:23 PM »
Long cables can make electronics unhappy.  If you're going to use the electronics for tip weight you probably want to run the battery and receiver together, with a long wire to the servo.
The latest el-cheapo Hobby King car radio is 3-channel, with a button on the grip for the 3rd channel.  You could use that for cutoff, and have a transmitter for flying carrier planes.
Modern ABC and ABN engines are fairly tolerant of lean runs -- and lean runs are few and far between if you've got your setup right.
Offline Igor Burger
Re: Over Runs
« Reply #16 on: September 11, 2015, 04:33:17 PM »
You can use the same timer, small Lipo 1 cell battery and micro servo, it will be less then 1/2 oz
Re: Over Runs
« Reply #17 on: September 11, 2015, 04:33:48 PM »
Use a TUT with a cutoff loop programmed in.  It's how Howard Rush does it.
Offline Dick Pacini
Re: Over Runs
« Reply #18 on: September 11, 2015, 05:49:26 PM »
There was some discussion a while back about cut-off loops being considered grandstanding.  I always liked them.
To me, the absolute best cut-off loops were done by Al Rabe.  Perfect control and consistency and watching that big Sea Fury do exactly what he wanted when time came to shut down and land was a thing of beauty and a joy to behold. y1
AMA 62221
Offline Norm Furutani
Re: Over Runs
« Reply #19 on: September 11, 2015, 07:00:49 PM »
Here's the link to Airtek radio DT.  http://www.airtekee.com/RDT.php. Airtek, Kenny Bauer has been a pioneer in electronic FF goodies. There are two basic versions, a stand alone system that operates a servo or other actuator and one that interfaces with an electronic timer. Ken speaks controline so make sure he is aware of its use. Example: some have an immediate response and some have a battery saving delay.
Norm
Offline Target
  • C/L Addict
Re: Over Runs
« Reply #20 on: September 11, 2015, 07:35:50 PM »
I hadn't thought of that, but being the person I am, I could say that a "smart guy" might have the timer run timed, trusty Seiko S321 watch in pocket, and manipulate the last laps of flight to be in the right place at the right time.
I would think its doable with some practice....
But I do get your point, and your plan certainly gives some added flexibility once its mastered.
Again, exactly why I subscribe here.
R,
Chris
Chris
AMA 5956
Re: Over Runs
« Reply #21 on: September 11, 2015, 08:11:15 PM »
I see Paul Walker checking his watch toward the end of the flight.  I think he flies high or low laps to move where the airplane will cut out (I've also seen him do a "cut off loop" right as the time runs out).
Howard Rush had me program one of Tim's Universal Timer outputs to time the flight.  He runs that output to an LED in the plane so that toward the end of the flight it starts blinking once every 5.2 seconds (or whatever he programs in).  It's bright enough that he can see it even in direct sun.  It's timed so that at the end of the last blink the timer cuts out, so he flies his last few laps fast or slow to the same effect as Paul does, only he keeps his eye on the plane.
http://atomiczombieworkshop.com/tut/tut.html
Offline Target
  • C/L Addict
Re: Over Runs
« Reply #22 on: September 11, 2015, 10:38:09 PM »
Good to know I'm not that far off base.
I never thought so, but being tested occasionally isn't a bad thing...
And I'm still very interested in being able to manipulate a glow engine run.
I'll have to discuss that with my engine mentor before I convert him to electrics.
Kind regards to all.
Chris
Chris
AMA 5956
Offline Igor Burger
Re: Over Runs
« Reply #23 on: September 12, 2015, 12:15:47 AM »
And we, with tired eyes after flight, not looking to model last laps of flight have beeping and vibrating stopwatches in pocket telling us exactly the same, so I not only know exact place where motor stops, but I can also manage him to stop wherever I want (for example regarding the wind direction or even large rocks/holes on some official FAI WCh circles  VD~ ) ... and they even allow us measure lap time as a bonus  H^^
Re: Over Runs
« Reply #24 on: September 12, 2015, 10:15:34 AM »
True.  But you have to admit, when it comes to a proliferation of blinking lights, Howard's plane has yours beat down to the ground.
