  • July 18, 2025, 01:12:27 AM
Author Topic: Elevator Slider Nut  (Read 3822 times)
Offline Larry Fernandez
Elevator Slider Nut
« on: June 04, 2013, 01:46:38 PM »
Where, besides Control line Central can I get those slick adjustable elevator slider nuts?
Larry, Buttafucco Stunt Team
Offline Bob Whitely
Re: Elevator Slider Nut
« Reply #1 on: June 04, 2013, 02:28:31 PM »
Talk to Tom Morris. He has everything you need. Also Eric Rule might have
something you can use. RJ
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #2 on: June 04, 2013, 03:13:06 PM »
Yep, Tom has them..
I make mine out of 4-40 nyloc nuts. Pretty sure I got the idea from a post on one of the forums. Hard part is you need a mill to machine the flats on each side of the nut.
« Reply #3 on: June 04, 2013, 04:50:31 PM »
How does one contact Tom Morris?
I tried calling Eric but the phone is off the hook and glued to his ear.  HB~>
Offline Balsa Butcher
  • High Desert Flier
« Reply #4 on: June 04, 2013, 05:40:26 PM »
Hey Larry, do you need just the nut? as in have the slotted elevator horn, just need the slider part? 8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #5 on: June 04, 2013, 07:02:41 PM »
Yes Pete, I have a couple of horns, but I seemed to have misplaced the sliders.
I suck.
« Reply #6 on: June 04, 2013, 07:13:49 PM »
Couldn't you make one with the careful application of a file to a regular old nut?
I'm not criticizing, just wondering...
« Reply #7 on: June 04, 2013, 07:23:28 PM »
I have:  ctmorris at cableone dot net
I'm pretty sure that's current. He'll send you what you want with an invoice (you must pay the bill after getting the parts!).  H^^ Steve
« Last Edit: June 04, 2013, 08:05:12 PM by Steve Helmick »
« Reply #8 on: June 04, 2013, 07:48:26 PM »
I suck.
Larry,
Send me a PM with your address and I'll send you a couple of slider nuts w/screws.  I have a bunch of them.
That will tide you over until you can get hold of Tom.
  • High Desert Flier
« Reply #9 on: June 04, 2013, 08:04:35 PM »
I was going to make the same offer. If things fall through let me know and I'll get one in the mail.  8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline Bob Whitely
« Reply #10 on: June 04, 2013, 10:07:48 PM »
Larry, If you get some of these make sure you send each of them a couple
rolls of your best Monokote! You know, the stuff you use to make your
planes shiny.  RJ
« Reply #11 on: June 04, 2013, 10:50:01 PM »
planes shiny.  RJ
UUUhhhh....I already have some of that stuff...I'm just not as good at polishing it as Larry!
 LL~ LL~ LL~ LL~
Offline Steve Bakac
« Reply #12 on: June 05, 2013, 07:53:54 AM »
G/Day Larry
                    Brodak's sell them  item BH-882  in control horn section
      Regards Steve
« Reply #13 on: June 05, 2013, 08:28:21 AM »
Many thanks to all of you!!!
Randy did you get my PM ? I sent it through this board, but it got kicked back a couple of times.
If not my address is
Larry Fernandez
282 Bangor Ave
San Jose, Ca 95123
I can use two slider nuts immediately
I misplaced a small zip lock bag of them and didn't realize they were missing until the very moment That I needed them.
Thanks again fellas
« Reply #14 on: June 05, 2013, 08:40:40 AM »
Larry Fernandez
282 Bangor Ave
San Jose, Ca 95123
Thanks again fellas
Larry,
They're in the mail this morning!
Not sure what's up with the PM's.  I didn't recieve any.
« Reply #15 on: June 05, 2013, 01:20:39 PM »
I make my own out of some soft steel I have. Pretty easy, really.
« Reply #16 on: June 05, 2013, 08:32:50 PM »
I'm lazy...I don't make anything anymore that I can get as cheap and good as these things.
I used to make my own control horns, but don't do that any more either.  It's really fun being lazy!  More flying time!
PS:  Larry, the slider nuts went to the postoffice early this morning.  You should have them by friday.
« Reply #17 on: June 05, 2013, 08:45:26 PM »
    Need to be a little careful with these. I think they are too narrow and don't engage enough of the horn upright. And make sure you put a hard washer under the ball where it bears on the upright. Jim didn't, tightening the ball spread the sides of the upright slot, and eventually it slipped and crashed the airplane. At the NATs, of course.
