  • July 20, 2025, 09:08:28 AM
Author Topic: My Shop Is Finally Finished!  (Read 1539 times)
Offline Dick Pacini
« on: September 02, 2011, 03:28:32 PM »
Well, after 3 years, it is completed.  I built it in the worst part of the basement that had a dirt wall and water problems.  It was quite a challenge to block up the wall, but the guy I hire for stuff like that is very good.  I pulled the insulation out of the ceiling and replaced with acoustic tile.  Insulation isn't needed if the basement is heated.  I ran all new wiring and have GFI outlets every few feet on two walls.  A new 4 bulb overhead fixture gives plenty of light.  The ceiling fan was there, so I worked around it.  I put 3 coats of light yellow paint on the cement and block walls.  I left the new wooden wall natural.
I built a bench to hold all my small power tools.  Unfortunately, the 8X11 room can't accommodate my lathe, so I had to leave that on the other side of the basement.  The building bench is a great value from Harbor Freight.  It was on sale and I had a coupon for 20% off.  I picked it up at the store for about $120.  You can't build it for that.
I have already stocked it with all my kits, engines and modeling stuff.  Now, I have no excuses.
AMA 62221
Offline Dick Pacini
Re: My Shop Is Finally Finished!
« Reply #1 on: September 02, 2011, 03:36:24 PM »
Need to split the pix.  Here's the rest:
AMA 62221
Online Paul Taylor
« Reply #2 on: September 02, 2011, 04:52:07 PM »
Looks great. Wish I had a basement. Now cut some wood!
Offline bruce grosser
« Reply #3 on: September 02, 2011, 06:05:07 PM »
Hello Dick    Thanks for the info about Mc Master-Carr I'll be placing an order as soon as I determine whatever else I can't live without.  I thought of you last week when the ambulance  passed routing info on, I 91 South ,for Charlestown. I was headed to Boston; the result of a routine stress test run amok. Consequently I have been internetless since monday before last. I think it would be a great idea if who ever's in New England could get together. Maybe not even to fly ,just meet and commune. You can call me [or anybody else can, for that matter]
at 802 467 3934. I'll be here 24/7 for the next 2 months.      Thanks again   Bruce Grosser
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
« Reply #4 on: September 02, 2011, 07:21:07 PM »
I just know if that basement were mine, I'd stick a wing into that ceiling fan while manipulating my plane around...probably multiple times.
--Ray
AMA902472
Online Matt Colan
« Reply #5 on: September 02, 2011, 07:30:52 PM »
It's missing one thing..........
SAWDUST!!!   ;D
Offline Dick Pacini
« Reply #6 on: September 02, 2011, 07:50:07 PM »
Funny you should mention that.  Tonight, when I opened the door, I heard and felt the fan hitting the top of the door.  It shouldn't have because it has clearance...at least, it did have.  One of the blades had de-laminated and the lower section had drooped down far enough to clip the door.  It was an old fan that was there during many days of wet basement.  It smelled kind of funky, too.
My first project will to be make new blades.  I have scrap plywood left over from the new wood wall.  Then, I can use the new saws and sander...then the shop-vac to suck up that nasty sawdust!
AMA 62221
« Reply #7 on: September 02, 2011, 08:24:26 PM »
Cool shop. I especially like the lathe. Now get building!!   mw~   ;D
ChrisSarnowski
« Reply #8 on: September 02, 2011, 08:26:18 PM »
Hey,
You local guys should plan to come to the Mass Cup contest next weekend Sept 10-11 in Wrentham MA !!!
-Chris
Offline Dick Pacini
« Reply #9 on: September 03, 2011, 06:02:05 AM »
Hey,
-Chris
I would love to, but have a graveyard shift on the 10th and a 2nd shift on the 11th.  Maybe next year.
AMA 62221
Offline Steven Kientz
« Reply #10 on: September 03, 2011, 06:46:57 AM »
What pitch will the new fan blades be?
Steve Kientz
AMA 855912
« Reply #11 on: September 03, 2011, 07:08:48 AM »
Very nice shop Dick. My shop is spread between a back bedroom and one end of the basement. I have acquired a few power tools over the last few years, a bench grinder, drill press, and a band saw. Every time I go to use them I remember the days of using razor blades for cutting balsa, and a coping saw for plywood. It just took a little longer. Way back when, I use to use one of those egg beater hand drills with flattened nails for drill bits. My first power tool many years ago was a hand drill and a set of real drill bits. But I did manage to scratch build many planes with those early hand tools.
Offline Chuck Feldman
« Reply #12 on: September 03, 2011, 07:22:53 AM »
Dick,
I wish you the very best with your new shop.
Chuck
Chuck Feldman
AMA 15850
