  • June 22, 2025, 07:39:41 PM
Author Topic: Venturi and needle valve assembly for OS LA .40 and FP .35  (Read 1501 times)
Offline dagored
« on: July 11, 2022, 07:31:04 PM »
who make's or sell's Venturi's and needle valve assembly for OS LA .40 and FP .35 ....
Offline Walter Hicks
Re: Venturi and needle valve assembly for OS LA .40 and FP .35
« Reply #1 on: July 11, 2022, 09:18:29 PM »
Shtterman on Ebay- He has everything you need . Great to deal with super good service . I have used him for years
Offline dagored
« Reply #2 on: July 11, 2022, 09:22:47 PM »
Ok Thx Walter ..... H^^
Offline dagored
« Reply #3 on: July 11, 2022, 09:26:16 PM »
is there any one else than that guy ,  Shtterman on Ebay- ...???
« Reply #4 on: July 11, 2022, 09:28:46 PM »
Get in touch with Randy Smith. He's on this forum in the Vendor section under Aero Products.
Offline dagored
« Reply #5 on: July 11, 2022, 09:32:21 PM »
Thx Motorman ....
Online Paul Taylor
« Reply #6 on: July 11, 2022, 09:41:00 PM »
 Jim Lee might have them. You can find him in the vendor section.
Offline dagored
« Reply #7 on: July 11, 2022, 09:45:29 PM »
Thx Paul ...
Offline Reptoid
       Don
       AMA # 3882
« Reply #9 on: July 12, 2022, 05:41:12 PM »
If it matters (it probably doesn't), as one who prefers the Randy Smith NV assy. over all others, and really doesn't care for the OS .35S type NV assy., I'd definitely vote for drilling the threads out of the case. Why? 1) The OS NV assy. has that danged clicker style ratchit bs that is a PITA to install. 2) The NV itself has an annoying failure mode when it is damaged (i.e., bent) and it LOOKS ok, but in fact is NG and won't give any logical adjustments. 3) WHEN you need to borrow a NV Assy. at the field (because yours went Tango Utah), the odds are better that you'll be able to find a .156" (4mm) unit.  y1 Steve
Tags: need
