  • July 12, 2025, 05:37:19 PM
Author Topic: The bowling ball fallacy, it is just wrong  (Read 1787 times)
Offline Ty Marcucci
« on: February 13, 2010, 02:27:35 PM »
 H^^
« Last Edit: May 04, 2017, 02:53:02 PM by Ty Marcucci »
Ty Marcucci
Re: The bowling ball fallacy, it is just wrong
« Reply #1 on: February 13, 2010, 03:21:07 PM »
Pattern distortion due to flying the surface of a sphere haqs been explained time and time again.  It seems to grab editors as something truly inspirational, but it is simply a re-hash of the same stuff.  I mean, I could write my own theory based on the geometry already presented.  And I'm not even a judge!
Offline Bruce Perry
« Reply #2 on: February 13, 2010, 10:58:10 PM »
even better use a transparent umbrella  comes in handy for lots of stuff.....
B
Offline Jim Thomerson
« Reply #3 on: February 14, 2010, 10:27:04 AM »
Some years ago, Charles Mackey had an article in MAN using a transparent hemisphere.  Maybe Keith Trostle has done the same.  One needs two viewpoints: the view of the pilot from the inside of the circle, and the view of the judge outside the circle on the upwind side.  So a transparent hemisphere is needed.
« Reply #4 on: February 14, 2010, 11:07:46 AM »
....The judges and the "pilot" do not see the pattern in this manner. They see it from INSIDE the dome, not the outside, thus the pattern shown is what a viewer on the opposite side of the pattern might see. A better way to show the pattern is to use the inside of a globe. They do exist, in clear plastic and are bigger than a bowling ball.......
or get a copy of Keith Renecle's pattern sim and you can see each maneuver from any position you want, in detail, right down to the 5 ft. corners.  Amazing, and should be in every judge's toolbox.
« Reply #5 on: February 14, 2010, 07:19:41 PM »
Click top center on the home page.
Offline Pinecone
« Reply #6 on: February 16, 2010, 08:47:45 AM »
If you want to be totally right, it isn't really a hemisphere.  Because your shoulder is above the ground.  From shoulder height and up, it is a hemisphere.  But below shoulder height is is part of the rest of teh sphere. :)
Terry Carraway
AMA 47402
Offline Dick Pacini
« Reply #7 on: February 17, 2010, 09:55:17 AM »
I mentioned this a while back...I was fooling around with my world globe, trying to figure out why square loops aren't square and why the top of the square is arced.  The Lat/Lon grid on the globe made it immediately clear why.  Take a look at a globe.  It's not just for geography anymore!
AMA 62221
