  • July 19, 2025, 06:36:08 PM
Author Topic: ST v60 with no Muffler Lugs - Need Tongue Muffler with Mounting Strap  (Read 918 times)
Online Dennis Nunes
I have a ST v60 with no muffler lugs. Does anyone make a tongue muffler with a mounting strap?
Dennis
Hi Dennis
I sell the one that bolts on. here is how people use it, I send with 4-40 x 1/4  aand people buy a small worm drive stainless radiator hose clamp, you open it up and bolt both ends to either side. Or some make a steel   "U"   that the bend to a L at the  ends and  bolt on, other  drill 1 hole in the center of the  tongue muffler, and bolt to the   R/C  butterfly web in the exhaust center//I do not recommend that... although I may have an Adamisin  tube setup like that
Randy Smith
I'll Take It !  gimme a p.m. if you find one, or two . . . .
