Finally got all of the inards of my 46FX replaced and re broken in. First flight was Saturday. Whomever told me earlier that the FX had a "bit" more power than the LA needs to look up the definition of "a bit". I have a beast on my hands. I fly a 60" 650Sq 18% wing on a 52oz ship with an 46LA for now. Flies great on 63' lines (e2e) with a 5.5 lap. I dropped in the FX and it turned a 4.0 on the same 11-5 prop I use on the LA and that was running a fast 4 cycle which is about as slow as it wants to run smooth. It has more raw power than some of the .60's around here.
I am not much of an engine man so I did what research I could and found nothing on the 46FX that was not part of one of my earlier posts so I am asking for some advice. I am building around this engine and as of now the plane will have 690 squares 22% airfoil and a target weight around 60oz. That is only a slight increase over what I flew it in Saturday.
So, how do I harness this beast? I have no clue as to props, etc. on larger engines. I know the 11-5 is not right but what is? The rest of the story is a ST NVA in the primary with about a .270 venturi and a rear NV, 10% Wildcat fuel, and no additional head gaskets.
I am open to anything - Ken
Follow Up - Never thought to search on the 46AX and I did find some advice there. Interestingly I also found the 46FX mentioned but none of them were on the 46FX Search - Hummm....
What I seem to have found is a 12-4 prop, a .250 venturi and a big-ass plane. This is "Bear" country and we have quite a few running anything from .50 to .70 engines with and with out pipes but none of them are running 4.0 laps so, I am guessing the thicker wing will help. I can go to 68' lines but that would only take me to a 4.7 or so.
Thanks - Ken
