  • July 17, 2025, 02:39:47 AM
Author Topic: OS LA 65.  (Read 1145 times)
Offline Kerry Ewart
OS LA 65.
« on: September 18, 2006, 02:43:15 PM »
I have seen a lot posted obout the 'LA 46".But not the 65.
I was just wondering if anyone has used or tested one of these engines.
"If you cannot beat them!JOIN THEM.
Offline Leester
Re: OS LA 65.
« Reply #1 on: September 18, 2006, 02:54:09 PM »
The main problem with the 65 is it's weight. James Gifford had one in a Sig Fazer and it had lots of power but as I said it's heavy.
Leester
ama 830538
Re: OS LA 65.
« Reply #2 on: September 18, 2006, 05:47:46 PM »
Lee is right...the weight is up there,
also the LA has no bearing, so you can buy a better motor for the same price that is of the same power and a lot smoother...ie the Super Tigre 51. which is ringed and has bearings..
