  • June 29, 2025, 10:07:51 PM
Author Topic: OS LA.46 Blue engine or silver Whats the difference??  (Read 9860 times)
Offline Michael Graves
« on: June 18, 2012, 03:19:11 PM »
I need some info on the LA 46 engines is there a difference from the "blue" engine and the silver engine? And ifso what one is better and what is the difference?
Failing to practice is practicing to fail.......
Offline Claudio Chacon
Re: OS LA.46 Blue engine or silver Whats the difference??
« Reply #1 on: June 18, 2012, 03:30:40 PM »
As far as I know, just the color.
Offline Dennis Moritz
« Reply #2 on: June 18, 2012, 07:46:54 PM »
Blue is no longer manufactured. Far as I know.
Offline Gene O'Keefe
« Reply #3 on: June 19, 2012, 08:01:25 AM »
Both above answers are correct.
Gene O'Keefe
AMA 28386
« Reply #4 on: June 19, 2012, 09:21:12 AM »
As already stated, it is just the  color.   I did crock pot the blue off my LA .40 which was on a profile.   Could not get consistent engine  runs while the blue was still on it.   My .46 still is in blue. H^^
« Reply #5 on: June 19, 2012, 02:17:12 PM »
I,ve had dozens of the 46's apart for modification, both blue and silver (aluminum), and there is absolutely no difference in any of the internal parts.  I have found differences in the size of supplied venturis, but that is not confined to either color.
Both blue and silver run the same.
OS stopped painting the engines blue because of problems with the process not because of any performance issues or internal changes.
Marketing gimmicks often wind up like that.
The LA 46 remains, in my opinion, the best available CL stunt engine for under $250 in existence.
There are a few minor mods that can improve them slightly but actually are not really necessary.
Mike Griffin
« Reply #6 on: June 19, 2012, 05:52:46 PM »
I agree Randy .. for the money..they are like a Timex watch...just keep a running....
Offline Scott B. Riese
  • Just a student of stunt
« Reply #7 on: June 19, 2012, 06:20:24 PM »
Randy..What are the MODS you are talking about???
Scott Riese
Portland, Oregon
AMA 528301
« Reply #8 on: June 19, 2012, 08:46:07 PM »
 VD~
« Reply #9 on: June 20, 2012, 12:00:06 AM »
Scott,
I've tried many mods on LA46's and a few on LA40's dating back to when they were first released as R/C only engines.  I tried head mods to lower compression and change squish area etc...most of those either proved not worth the effort or actually less effective than stock.
The one mod that is worth the effort is reshaping the ports in the sleeve (not changing the timing) to direct the incoming charge to the back of the cylinder.  The ports in the LA series are directly opposite each other and this results in slightly inefficient charging of the cylinder, in that a fair amount of the charge is lost out the exhaust port.  The ports were obviously made this way as a cost saving measure (and they do function OK).
Redirecting the ports typically increases fuel economy and seems to broaden the midrange power some...though I've never had any on a dyno to prove this.  I have had several back to back in an airframe, modified and unmodified and was convinced that the power loading in maneuvers was significantly better with the redirected ports.
It's a fairly easy mod but must be done carefully because the case must be machined inside to match the new port shape and the case is very thin in this area.
I wrote a lengthy post on this mod many years ago on Stuka Stunt.  No secrets.
The increased fuel economy of course is not subjective and can be effectively measured.  It does differ somewhat from engine to engine but typically uses about 1/2 to 3/4 oz less to do the pattern, using 10% nitro.  There is a little less reduction on higher nitro content!
I've done a bunch of these for different folks over the years, but it usuall adds up to about 50 cents an hour for the work so it definitely became strictly a friendly thing and then I got much to busy at my job with Raytheon to continue doing any engine work.  Now that I'm retired I have done a few recently.
That said I'd be the first one to say that the 46 runs very good stock and though these mods do apparently help they are not necessary for a good stunt run, and would likely only be appreciated (or even noticed) by and expert level flier.
Randy C.
PS:  I also tried some port timing changes but all resulted in loss of power or no noticible change at all.
It would be interesting to make an AAC sleeve set-up with port timing more like the Aero-tiger but that's another story altogether.
This post is probably more suited to the Engine Set up tips section but I wanted to answer your question here.
« Reply #10 on: June 21, 2012, 09:05:11 PM »
Thank you.....As I do rework to customers engines I want to have all of the possibilities in my file.
again thanks  H^^
Scott Riese
Portland, Oregon
AMA 528301
Offline Allan Perret
  • Proverbs
« Reply #11 on: June 26, 2012, 12:15:04 PM »
Randy C.
Do you think you might be able to relocate that post, would like to read it.
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #12 on: June 26, 2012, 01:35:01 PM »
Allan,
I can try when I get a few minutes from "Honey Do's".  It would be on Stuka Stunt sometime around 2000 time frame.  You can try!  If you can't find it I can send you a PM describing the process.  It's not hard but requires some very careful work with needle files and a Dremel tool.
Randy C.
