  • July 18, 2025, 06:26:28 PM
Author Topic: And now something a little different. Scraps  (Read 1446 times)
Offline David M Johnson
« on: September 24, 2015, 06:31:46 AM »
So having decimated a few planes over the last few flight sessions and moving I had some left over parts that to me seemed just to good to throw out so I made them into a plane that I will call SCRAPS.  This has parts from a trainer, a ringmaster, and the fuselage from a Argentinian design called Manacaca. The engine is gp25 that was kicking around and the monokote was left over from prior builds.  I put it together just because.
We're havin some fun now!!
Offline PerttiMe
Re: And now something a little different. Scraps
« Reply #1 on: September 24, 2015, 06:51:20 AM »
You need a longer propeller...  8)
How does take-off work out with single wheel?
« Reply #2 on: September 24, 2015, 08:02:48 AM »
With a single wheel the take off is the same, you just have to make sure to be ready to step back on release to maintain line tension.  The prop will be a 10X5 or 10X4.
« Reply #3 on: September 24, 2015, 08:07:47 AM »
Looks like fun!
Offline frank mccune
« Reply #4 on: September 24, 2015, 08:18:34 AM »
     Hello David:
     Do not sweat this setup! I just put a ST G20/.23 on a similar airplane and in the past, that combination has worked very well for me.  I have flown many planes with one wheel and many times I used a stooge to launch the plane!  The single wheel is great for flying over rough grass as it prevents the plane from nosing over upon landing.  I have gone as far as to place a skid on the bottom of the plane in lieu of any wheels.  This too works very well for hand launching and landing on grass!  I have also been known to place a small wheel on the top of the plane to protect the nva, Lol
        Good luck,
        Frank McCune
Offline Ward Van Duzer
« Reply #5 on: September 24, 2015, 09:59:38 AM »
David,
Good name! But who of us has not had at least one of these?
W.
« Reply #6 on: September 26, 2015, 03:58:52 PM »
When I did it I knew that I was not the first...
« Reply #7 on: October 06, 2015, 08:18:41 AM »
just a quick follow up flight report the maiden flight was good, no issues the plane flys very flat and level. It turns on a dime and is going to be a great trainer for maneuvers and inverted flight. The engine provided a good run so on to making a better pilot.
« Reply #8 on: October 06, 2015, 11:08:55 AM »
Isn't it great when a plane does what you want it to.
