  • June 20, 2025, 04:47:25 PM
Author Topic: os la 10  (Read 1562 times)
Offline Bootlegger
os la 10
« on: December 02, 2014, 09:25:33 AM »
 Did OS make an LA 10 engine? If so I sure could use one.
  Thanks a lot..
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline mike londke
Re: os la 10
« Reply #2 on: December 02, 2014, 09:34:50 AM »
BTW I don't see them on Ebay much but I almost always see a few at R/C Swap meets.
Offline Akihiro Danjo
Re: os la 10
« Reply #3 on: December 02, 2014, 09:40:31 AM »
OS had ever manufactured LA10, but R/C version only.
If you want to use it for C/L, you have to drill a spray bar hole and have to prepare a special venturi because the shank size is not the same as other models (FP10, etc).
Aki
Offline dennis lipsett
Re: os la 10
« Reply #4 on: December 02, 2014, 09:51:43 AM »
Jim Lee has a venturi for the LA10. Getting a nva is another story. OS stopped offering theirs about 6/7 years ago and there are others that might fit but you have to make sure the od is not too large. Also you cannot retro fit an 0S/FP 10 backplate to it as the case design has changed and the liner is too far down the case for the backplate to fit in.
I'm sure others will offer suggestions on an appropriate nva and yes the LA shows up on E-bay.
Offline Bootlegger
Re: os la 10
« Reply #5 on: December 02, 2014, 10:17:04 AM »
 Aki, I sent you a personel message..
Gil Causey
AMA# 6964
Online Motorman
Re: os la 10
« Reply #6 on: December 02, 2014, 08:34:44 PM »
I have one I'll sell you with a Cox venturi and needle valve installed. I bought it new and never ran it because I decided to go with an LA15.
Offline Bootlegger
Re: os la 10
« Reply #7 on: December 03, 2014, 05:31:56 AM »
  Motorman, I sent ya a P/M...
Gil Causey
AMA# 6964
