  • July 12, 2025, 03:31:46 PM
Author Topic: Os 25F vs. OS 25FSR  (Read 9088 times)
Offline Steven Kientz
Os 25F vs. OS 25FSR
« on: June 30, 2010, 02:28:28 PM »
Was the FSR an upgrade of the 25F? What are the differences?
Steve Kientz
AMA 855912
Online Paul Taylor
Re: Os 25F vs. OS 25FSR
« Reply #1 on: June 30, 2010, 02:34:06 PM »
I am not the expert, but I think the 25F is what Clancy had us use for our JYW plane. It was a real work horse! %^
« Reply #2 on: June 30, 2010, 04:44:51 PM »
the 25F is ABC - the 25FSR is steel liner iron piston........
« Reply #3 on: June 30, 2010, 08:20:42 PM »
Didn't know that!  Thanks, Wynn.
Mongo
Offline Wayne J. Buran
« Reply #4 on: July 01, 2010, 04:08:47 AM »
The FP is plain bearing. The FSR is dual ball bearing. I am not familiar nor do I remember an F.
Wayne
Wayne Buran
Medina, Ohio
AMA 14986 CD
USAF Veteran 35 TAC GP/ 6236 CSG, DonMuang RTAFB, Bangkok, Thailand 65-66 North Coast Controliners   "A fine is a tax for doing wrong. A tax is a fine for doing well!
« Reply #5 on: July 01, 2010, 04:10:46 AM »
Oh BTW the FSR was available in ring and ABC versions in several sizes although I am not familiar with a 25 ringed.
Wayne
Wayne Buran
Medina, Ohio
AMA 14986 CD
« Reply #6 on: July 01, 2010, 05:16:33 AM »
Wayne
I have a .25 F?? with BB and ABC(N??).  I have a new OS 10, on the box it has ".10F"  and I *think* it has SR below it.  Would have to dig it out and look at it to be sure.  But, it doesn't have the "SR" beside the "F".  Never had a "Box" to any of the other F-S-R engines so I don't know how they were designated.  My 2 OS .32s only have an F on them.
Good engines, though!
Big Bear
« Reply #7 on: July 01, 2010, 06:27:53 AM »
Thanks guys
The OS timeline shows several years between these engines, I just wasn't sure of the differences.
Steve Kientz
AMA 855912
Offline Clancy Arnold
« Reply #8 on: July 01, 2010, 08:19:03 AM »
In June 1977 OS introduced their new 25 Schnuerle ported engine.  This engine can only be identified by the case having ball bearings and a 25 in a circle under the exhaust.  In July & August 1977 OS advertisements called it a FSR.  That designation is only on the box.  It is rated at 0.8 HP.
In 1982 OS introduced the 25 F ABC engine.  It differs From the 25 FSR by the ABC construction and a F below the 25 in the circle below the exhaust.  It is rated at 0.8 HP.
In 1984 OS introduced the 25 FP which is a sport timed engine with Plain sleeve bearing.  It is rated at 0/6 HP.
I own samples of all three engines and did a comparison run on the different engines using the same 10 x 4 Top Flight Power Point wood propeller and 10% fuel.  Three 25 FP engines ran 9,800 to 10,100, the 25 FSR ran 10,800 and the 25 F ABC ran 11,000.  These tests were ran using the original RC Carbs and factory mufflers.
As a side note I measured the diameter of the hole through the carb throttle barrels on several OS engines.
The OS 25 FP comes with a 2A carb that has a .180 dia. hole.  This carb is an Air Bleed type carb and the spray bar goes all the way across the hole.
The OS 25 FSR and 25 F ABC comes with a 2B carb that has a .216 dia. hole.  This carb is a dual needle type carb and the spray bar only goes half way across the opening.
For comparison the OS 40 FP comes with a 3A carb that has a .205 dia. hole.   This carb is an Air Bleed type carb and the spray bar goes all the way across  the hole.
In 1989 OS introduced the 25 SF ABC Ball Bearing engine that replaced the 25 FSR and F engines and can be identified by the SF on the left side on the engine.
Clancy
Clancy Arnold
U/Tronics Control
« Reply #9 on: July 02, 2010, 08:17:06 PM »
Thanks Clancy
Steve Kientz
AMA 855912
