  • July 18, 2025, 12:42:13 AM
Author Topic: OS 25 FP help  (Read 1036 times)
Offline Phillip Kenney
OS 25 FP help
« on: April 17, 2010, 02:08:13 PM »
Im converting an OS 25 FP r/c to control line. When installing the needle assembly, which way does the spraybar hole go? Towards teh front, stratght down, angled down?
Offline dennis lipsett
Re: OS 25 FP help
« Reply #1 on: April 17, 2010, 03:30:50 PM »
The hole goes downward. In tightening it if it moves slightly back it won't affect the running characteristics.
Re: OS 25 FP help
« Reply #2 on: April 17, 2010, 05:28:23 PM »
     This is (as with most things) a poin of argument. The absolute best  position, from some perspectives, is something like 80 deg from the flow direction. But putting is straight down works about as well most of the time, and is probably better from other perspectives. It's not at all critical - I have seen them with the hole *up* that ran just fine.
Offline Bill Heher
  • Fix-it
Re: OS 25 FP help
« Reply #3 on: April 17, 2010, 09:48:56 PM »
I install mine with the hole aligned to the centerline of the venturi- i.e. angled to the rear of the engine a tad instead of straight down and parrallel to the cylinder centerline. I have 3 of them and have flown them on the 3
" usual suspects".
Flite Streaks, Ringmasters, SkyRay 35.  All ran fine - both with old school perfect Wedge tanks and stock venting, or plastic tank with clunk pick-up and muffler pressure.
Bill Heher
If it's broke Fix-it
