  • August 01, 2025, 06:39:07 PM
Author Topic: Original Top Flight Tutor CG  (Read 832 times)
Offline Michael Graves
« on: June 04, 2012, 06:29:42 PM »
Can someone tell me What the CG is on the original top flight Tutor? Also what is the best prop for a 25-30 year old FOX 35 (That is what I have mounted on the plane.
Thanks, Mike
Failing to practice is practicing to fail.......
Offline Darrel
Re: Original Top Flight Tutor CG
« Reply #1 on: June 04, 2012, 06:36:39 PM »
The plans show a range of 2 to 3 inches from the leading edge.
Darrel
ChrisSarnowski
« Reply #2 on: June 04, 2012, 07:17:37 PM »
Hey, you can use the same prop you would use on a 50 year old or 1 year old Fox 35. :)
10x6 prop, what's handy, say APC or Zinger both worked on mine. You can use a fancier prop too.
-Chris
Offline kenneth cook
« Reply #3 on: June 04, 2012, 07:51:07 PM »
                   Hello Michael, I flew the original Tutor in beginner and right up to intermediate. I learned many things from flying this plane. Like yours, I had a Fox.35 on mine as well. On nice mild days it was a joy to fly. Once the winds started bouncing it around, it was time to park it.  I didn't build my plane, I actually rebuilt it. That being said additional wood and adhesive and paint probably had mine in the not so favorable weight zone. The Fox was working hard to keep up. The Tutor's wing could certainly use improvement. Since we obviously can't change that we have to keep it flying steadily through the maneuvers. I subscribe to the big plane, big prop theory. A 10x6 worked well , although it could also be improved with a 10 x 5 . If your using the stock muffler, it may need modification and or a tongue. You have to get rid of that heat. This will certainly have a affect on what props your swinging. I found that eliminating the rudder offset and swinging the leadouts fwd. really gained the speed needed to fly through the maneuvers steadily. This plane taught me about yaw and how it affects your fuel tank. Getting rid of all the drag being created by the plane trying to fly out of the circle vs with the circle allowed my props to work a whole lot better. Ken
« Last Edit: June 04, 2012, 09:05:40 PM by kenneth cook »
