  • July 13, 2025, 04:54:08 PM
Author Topic: Props...  (Read 1004 times)
Offline Bootlegger
Props...
« on: February 09, 2007, 12:11:38 PM »
 Guy's I posted this on SSW and want to do so here.  I am looking at changing the pitch on some props and have read that working the front is the way to do it..  I have also read to work the back. What do the experts say and why do you do it your way ...
  " Inquiring minds want to know"... HB~> mw~
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: Props...
« Reply #1 on: February 10, 2007, 08:11:45 AM »
First thin of real importance is to have a top notch Pitch Gauge.  I have one that was made just for F2C props way back when I was trying the event.  But, the designer of it also made an additional gauge for bigger props.  Basically if you are using carbon props you need something to heat the water in.  I would not even consider reforming nylon props, even the the composite ones.  Wood blades you need a good set of files and lots of sandpaper.  On all props you change the pitch on the backside of the blade.  After the pitch is set, then you thin down the prop on the front(airfoiled side).  Myself at made stage of competition I stay with wood or APC props.  I have quite a selection to choose from and play with.  Now for the carbon guys to step in and let us know how they do it.  DOC Holliday
