  • July 30, 2025, 09:11:09 PM
Author Topic: Opinion wanted  (Read 896 times)
Offline Bill Sawyer
Opinion wanted
« on: June 29, 2008, 09:21:41 PM »
In several of the kits I have produced, I have included a pair of metal pads to be used under the engine. Would you like to have them included in more kits or should it be left to the builder to decide when the kit is built?
Bill Sawyer
AMA 53987
Windancer Models
Re: Opinion wanted
« Reply #1 on: June 30, 2008, 01:52:08 AM »
I'm using the ones provided in the Playboy kit.
But that probably doesn't answer your question.
Re: Opinion wanted
« Reply #2 on: June 30, 2008, 07:16:38 AM »
I know it is more work, but, the pads sound great to me.  Maybe when the shop is done I will get started on my "Playboy".  DOC Holliday
Offline Charlie Pate
Re: Opinion wanted
« Reply #3 on: June 30, 2008, 10:31:06 AM »
 If the kit were a full bodied plane,with an inverted engine : I would feel the aluminum mounts a plus.IF they were
 on top of the mount and not embedded in the mount.
IMHO, this would allow you more leeway in your fuel tank height adjustment.
it would also allow you to a thicker tank,if you needed more fuel capacity for your engine and could not make
the tank longer due to nose length design.
 Obviously,I would in corporate this in any scratch built plane I was constructing.
Offline Bill Hummel
Re: Opinion wanted
« Reply #4 on: June 30, 2008, 10:57:15 AM »
Bill, I agree with Mr. Pate; use the metal pads, preferably on top of the motor mounts.  Does give "flexibility" in tank matters...
ama 72090
