  • June 30, 2025, 01:30:45 AM
Author Topic: Eldorade  (Read 1250 times)
Offline Bootlegger
Eldorade
« on: April 13, 2018, 06:15:21 PM »
  Do we have any contest info on this contest, such as motels and the dates and times?  Thanks ...
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline James Holford
Re: Eldorade
« Reply #1 on: April 13, 2018, 06:18:14 PM »
May 5-6th
Jamie Holford
Baton Rouge Bi-Liners
Lafayette, La
AMA #1126767
Offline Dan Berry
Re: Eldorade
« Reply #2 on: April 13, 2018, 06:28:26 PM »
Me and Mark Troutman will be there.
What else could you ask for?
Re: Eldorade
« Reply #3 on: April 13, 2018, 06:45:22 PM »
Case of Pabst and a radio 🤣
 If this oral surgary i have to get doesnt fall on the friday before I will be there!
Jamie Holford
Lafayette, La
AMA #1126767
Offline Jason Cunningham
Re: Eldorado contest
« Reply #4 on: April 13, 2018, 07:04:30 PM »
JOHN GUNN OPEN INVITATIONAL
CONTROL LINE STUNT CONTEST
May 5-6, 2018
(KENNETH MAKEPEACE FIELD ON 736 INDUSTRIAL ROAD, EL DORADO, ARKANSAS 71730)
AMA Sanctioned Event #18/350
Saturday:
Unlimited Profile (BIAE) – No appearance points.
Classic (OPEN) – Appearance points
War Bird (OPEN) – Appearance points
Sunday:
Precision Aerobatics (BIAE)
Appearance points (ARFs 0-10 points) (ARCs or modified ARFs 5-15 points)
Marvin Denny Rule for ARF's & ARC's appearance points.
WARBIRD STUNT - Rules and guidelines as follows:
o Warbirds must be readily recognizable for the airplane they represent.
o Modified nonmilitary aircraft made to loosely resemble military aircraft will not be allowed (i.e., modified, Twister, Veco Chief, Ring Master, etc.)
o May be constructed of profile or Built-up fuses.
o Aircraft must have military finishes, or finishes that depict their mission. No air-racing finishes, or fancy air show paint schemes allowed. Paint schemes of military demonstration aircraft will be allowed.
o Appearance points will be awarded if pilot is the builder.
o Contestants will fly the modern stunt pattern.
o This will be an open event - no skill classes.
o There will be an award for the BEST WARBIRD- Based on the likeness to the aircraft it represents, and fit/finish. Contestant must be the BOM. The pilots will decide the winner.
o Stunt Awards for 1st, 2nd and 3rd place.
o The purpose of the event is to have aircraft that represent the military theme for the sake of honoring the men who flew them, the hard working men who maintained them, the men who designed them, and the men and women who built them.
$15 first event, $5 additional event
Asphalt and grass circles
Awards, raffle prizes, Pilots Choice Awards
Pilots Meeting at 9 AM
Concessions available
Field open on Friday
Open Invitation
Motels within 2 miles of field:
Hampton Inn 870-862-1800
Holiday Inn Express 870-881-8900
La Quinta Inn 870-863-6677
Comfort Suites 870-863-4300
Super 8 870-862-1000 ** LOWER RATES-NICE
Econo Lodge 870-862-5191
If you are unable to book your room through the motel websites, call the motels directly. The different websites show no vacancies because the rooms have been blocked off for contractor use. However, at this time, motels have openings for the weekends- Fri. afternoons thru Sun- specifically May 5th-May 7th rooms should be available if you call the motel desk.
Sponsored: Model Aviators of South Arkansas (AMA #3185)
Contact:
CD: Jason Cunningham (870-814-6005) jcunningham50@hotmail.com
CD: Doug Patterson (225-270-2181) jd3patterson@gmail.com
Offline Bootlegger
Re: Eldorade
« Reply #5 on: April 14, 2018, 05:58:11 AM »
  Thanks Jason, I appreciate the heads up..
Gil Causey
AMA# 6964
Re: Eldorado, AR contest
« Reply #6 on: April 18, 2018, 05:22:00 PM »
Awards given to pilots at the John Gunn Stunt Contest include:  LL~
Pilots Choice Awards 2018:
Profile, Classic and PA
Award for Top Gun pilot 2018
 H^^ We have some good raffle prizes to give away too !!
Offline Dan Berry
Re: Eldorade
« Reply #7 on: April 18, 2018, 08:44:51 PM »
Oh, by the way...
If anyone wants Powermaster 10/22 fuel, let me know.
Re: Eldorade
« Reply #8 on: April 18, 2018, 09:35:54 PM »
Oh, by the way...
Free fuel for everyone!!! 🤣
Jamie Holford
Lafayette, La
AMA #1126767
