  • July 06, 2025, 10:04:22 AM
Author Topic: Not Your Father's Flite Streak  (Read 1961 times)
Offline Leonard Rennick
« on: October 01, 2011, 09:59:04 PM »
Flite Streak wing that morphfed into an 80% P-Force or a Jr Force, as Mike Pratt and I named it several years ago. MonoKote over silkspan all trim is MonoKote while paint is KlassKote. Power is FP25, weight came in at 30oz, first flight to come Sunday.
Leonard
Leonard Rennick AMA 865846
Offline Crist Rigotti
Re: Not Your Father's Flite Streak
« Reply #1 on: October 01, 2011, 10:08:57 PM »
Nice.
« Reply #2 on: October 01, 2011, 10:14:11 PM »
I like your tank mount.
« Reply #3 on: October 01, 2011, 10:26:38 PM »
That's pretty cool.  We look forward to hearing how it flies.
Offline builditright
  • So happy to be alive!
« Reply #4 on: October 02, 2011, 04:48:05 AM »
thats pretty slick looking,
and where'd you get the gear?
Thank you and God Bless
Walter
aka/ builditright
« Reply #5 on: October 02, 2011, 06:48:26 AM »
Walter,
The gear is from Steve Wilk (Elimator Props).
Leonard
Offline afml
« Reply #6 on: October 02, 2011, 07:03:32 AM »
GREAT WORK Leonard!
Really like the outboard "scoop"!
How much longer is the fuselage from the original P-Force?
Keep us informed of the flight performance!
"Tight lines!" H^^
Wes
Wes Eakin
« Reply #7 on: October 02, 2011, 07:11:29 AM »
Very nicely done.
So what's it called? A Flite Force? ;D
Offline Mike Mulligan
    • Mulligan Racing Development
« Reply #8 on: October 02, 2011, 11:34:21 AM »
Very nicely done.
Maybe a P-streak....    :o
On second thought, ummm... No.
Mike Mulligan
AMA 789641
www.Mulliganracing.com Mike@Mulliganracing.com
« Reply #9 on: October 02, 2011, 02:43:22 PM »
I'd vote for "Morph Force" (pronounced "MorForce"), but it's already been named the "Jr. Force", per the original post. It does look kewl, and I like the morphcolors and morphgraphics...  LL~ Steve
« Reply #10 on: October 02, 2011, 06:38:22 PM »
As has been stated already, that is nice. H^^
« Reply #11 on: October 02, 2011, 06:44:42 PM »
 Neato! Should be a great flying little plane. y1
« Reply #12 on: October 02, 2011, 08:12:20 PM »
Flying results were great, three minor tweeks. Lower the fuel tank, add a half oz of weight to the rear, and seal the OS needle valve, which I should have done before.
As for the the question about the fuselage being longer than a P-Force, it's shorter than the P-Force, it's about 80% the size of the P-Force. This is the second one of these I've built, had too after rekitting the first one. The first one was built using a combat Cat wing and flew pretty good, but the Flite Steak wing is much better, as Mike suggested it would be.
Leonard
Offline Larry Price
« Reply #13 on: October 04, 2011, 11:56:21 AM »
Leonard
Can you explain "seal the OS needle valve"? Thanks
Larry Price
Edgewood, WA
Offline jim gilmore
« Reply #14 on: October 04, 2011, 12:45:29 PM »
Can you show a better detail on how the fuel tank is mounted ?
« Reply #15 on: October 04, 2011, 05:07:58 PM »
OS needle valves tend to leak at the junction between the needle and the spray bar the simple solution is to add a small piece of fuel tubing.  Place the piece of tubing on the spray bar and then screw the needle into it. Before I sealed the needle I had to open it 5 1/2 turns after it was sealed only 3 turns.
As for the fuel tank mount it's a piece of plywood, with added pieces of plywood glued to it for the mounting tabs. Then I glue a piece of mouse pad to the tabs and slot the tabs for adjustment. I then make a balsa wedge to angle the tank out about an 1/8 in, I use silicone glue to mount the tank and zip ties just for insurance.
Offline Kim Mortimore
« Reply #16 on: October 05, 2011, 08:59:02 AM »
Leonard,
I haven't heard about OS needle valves leaking.  How long is the piece of fuel tubing you use to seal it?
Also, how would you say the shorter rear fuselage affects flight performance?
Kim
Kim Mortimore
Santa Clara, CA
Offline Derek Moran
« Reply #17 on: October 05, 2011, 10:09:50 AM »
Leonard,
Please explain how you finished the silkspan prior to applying the MonoKote.  I assume you wanted a smooth, taut surface that was somewhat porous.
Thanks!
Derek
AMA 82617
« Reply #18 on: October 05, 2011, 07:21:45 PM »
Derek,
The piece of tubing is about 3/16 long. On suction I have not found a problem with the OS needle assembly, but as soon as you add some pressure all bets are off. As for the silkspan I stole the process from John Miller. Apply the silkspan as normal but put only two coats of dope over the open bays, as you said it needs to be porous.. If you can't find John's article on the process I'll send you a copy. My advice would be to stay away from the new MonoKote it just takes a ton of heat to shrink. You noticed I didn't follow my own advice as I really liked that wine MonoKote. Ultrakote is the way to go. I've been able to cover a large combat wing 600 inches with just one piece on each side and no wrinkles.
Leonard
