Hi John;
I prefer that engine over the LA.15 because it has twin ball bearings, and is a true ABC. Pop a custom designed venturi in the crank case, run a ST needle valve through the hole and you are good to go. Never had a problem with any of the ones I have sold over the years.
Eric
