The Rocket was made in different flavors, at least 2. One was made primarily for rat racing and is likely no good for stunt; however, one variety of Fox Rocket was just an economy engine (about $7 at the Base Exchange in the early 60s), and was a good general purpose engine. It was my first "big" engine and powered a variety of airplanes, starting with a Sterling Ringmaster. Although I never owned one, I believe the RR version had a MUCH larger venturi than the GP version and may have had a needle bearing on the crank (memory is weak after 50 or so years). I think the head was painted red, ala McCoy. The el cheapo version had a small venturi and bronze sleeve crank bearing, which wore out before the piston and sleeve in mine. My rocket served me well for over 20 years until the connecting rod finally gave up the ghost in about 1973, probably because I had started running RC fuel in it. I just pitched it in the trash bin at the time. I had not yet learned to be nostalgic. In comparison, I owned 2 McCoy Red Heads during the same period and neither lasted more than a couple years.
Bob Redmon
AMA 58073
