  • July 03, 2025, 11:20:59 PM
Author Topic: Old time  (Read 1361 times)
Dwayne
Old time
« on: March 28, 2008, 06:00:28 PM »
You know talking about Incedence meters and all this and howabout  that. How did the old timers build there models?!! The old I beemers!! and what not! The Neptune , Detriot Stunters and on and on! Aweseome airplanes and most of them had no plans!! They just built them from scratch!!!! I wish someday I can do that!! I wish!!
Re: Old time
« Reply #1 on: March 28, 2008, 06:14:26 PM »
Careful measuring.
Re: Old time
« Reply #2 on: March 28, 2008, 07:43:00 PM »
Watch Hunt's video on building I-Beams.  Of course back in the old days it was a secret.  DOC Holliday
Re: Old time
« Reply #3 on: March 29, 2008, 02:25:02 AM »
it's called the éyetrometer"
you have two of them!!! ~>
Dwayne
Re: Old time
« Reply #4 on: March 29, 2008, 07:05:49 AM »
Yeah Bob Hunt!! He is one of the greatest!! No question! Bob Hunt is one of the greatest!!  But when it comes to building I beems Bill is the one!!!!
Re: Old time
« Reply #5 on: March 29, 2008, 09:24:05 AM »
If you had a large flat surface, I-Beams were the easiest of all to get a straight model from.  Everything was its own *jig*.  Still my favorite style of building when I actually do build! LL~
Re: Old time
« Reply #6 on: March 30, 2008, 08:04:44 AM »
Also another of Bob Hunts video is the building of a lost foam wing.  A lot of detail on how to do it.  The easiest way is to get the set of wings from Bob.  Best bet is contact Bob.  DOC Holliday
Re: Old time
« Reply #7 on: March 30, 2008, 10:13:48 AM »
While the incidence meter can help, you can probably measure closer.  Case in point: Can you measure within 1/16"  if you are locating the wing onto the fuselage and make a 1/16" measurement error on a 10" wing chord that results in an error of 0.35 degrees. that is closer than you can see on the "needle" type incidence meters.  The digital type - maybe you could do better.
Of course if you can measure closer than 1/16"...!
On a 3" wide stab  (w/o elevator) a 1/16" error is 1.2 degrees.  You would surely see THAT with a meter, but again the needle type would be hard to completely see the correction!
Of course, meter or not the best way to assure alignment is with a flat fuselage top and a flat building board!
« Last Edit: March 31, 2008, 07:03:13 PM by Dennis Adamisin »
