  • July 17, 2025, 04:11:24 PM
Author Topic: Old stunters vs. new ones  (Read 32382 times)
Re: Old stunters vs. new ones
« Reply #50 on: August 09, 2009, 12:14:57 PM »
This is really in response to Randy as well as Ted and Brad and any others who subscribe to the idea that fidelity points can be based on things like
classic engine
classic prop
classic tank
classic finish
etc etc etc
AND
classic wheels
classic
color scheme
duplication of color scheme
classic spinner
correct aspect ratio
correct nose moment
correct tail moment
correct size/shape of flaps
correct LG position
correct cowl shape
correct canopy
correct cockpit detail
correct tail/elevator shape/areas
correct tip shape and construction
etc etc etc
First, before I get flamed on this, I basically understand the case that Ted explained above as well as what Randy discussed.  And I agree that the event is meant to be kept simple and fun and enjoyable and if providing documentation is not in the lexicon of a particular individual's fun things to do, then even the simplest of documentation should be avoided.
HOWEVER, even if the list of eligibility points is limited to period engines, tanks, props, finishes, etc etc etc, what are the judges to use as a reference to delineate between those models presented where one has just a "period engine" compared to one which has the exact same make and size of engine for that given design that the original used?  How is a judge to know unless there is some sort of presentation/documentation to be able to delineate between one really nicely done replica and another?  Or is there just a blanket award of 20 points for those models that "appear" to have a few of these "period" things and those that do not have a Froom spinner gets none?  I know that fidelity points could be and should be probably just like appearance points where the scores awarded are essentially a relative matter between the models actually being compared rather than a rigid scale based on what is or what is not represented on each and every model.
What I am trying to say and not doing a very good job at it is that in order for points to be equitably awarded while comparing those model entered in competition, there needs to be some basis for the judges to use other that some vague recollection, if any personal knowledge is had at all by any judge of the "period" equipment and/or designs.  That information could be in the form of listings, drawings, photographs, written explanation etc etc etc.
I do know that at some Classic contests where appearance points are awarded and no fidelity points are give, that appearance points have been reduced for those models which have obvious deviations from the original design regarding airfoils, or areas, or etc etc etc.
You make some very valid points, it certainly is not easy, If I were to suggest a way to help with A and F points it maybe something like this, Bring into Classic something very much like what was used when we flew those ERA planes
0-10 points for workmanship
0-10 points for finish of the model
0-10 points for fidelity.. a model that uses period parts,and is more true to the ERA on the finish.
 This could work like this
give 3 points for building the model like the older ones were, give 3 points for a period engine, give 1 to 3 points for things like old wheels,spinner,props, and use the remaining point for any other item that makes it comply with the fidelity clause.
On the same token you could take away 2 or 3 points from that total for things like improper structure or an obvious change that you know to exist
The CD or AP judge is NOT going to catch everything,and sometimes these will let planes slip thru, you just do your best . I think that is all we can ask, remember  the goal is to build fly and enjoy showing the older Classic designs.
You would have 30 points with 10 points available for awarding a person whom was being more true to the original designs and hardware, it would help the ones trying to stay with a period theme and be more true to what was flown then, but it would not be punitive to the rest of the flyers.
« Last Edit: August 09, 2009, 04:16:16 PM by RandySmith »
Offline Scott Hartford
« Reply #51 on: August 09, 2009, 01:02:09 PM »
"As to original engines, it never amazes me how some say they are so readlily available, when in fact they are not.   I'll bet those saying this say so because they have the engines in question. I don't and know very few that do. If you find one on ebay, it is way too expensive after all the bidding and or it is junk.  Been there, gone through that. Very seldom have I recieved a good one. "
Great Point TY , and one I have said for years, there are those that would like to limit what engines you can use, the fact is just as you stated, Period engines are hard to come by and get reallly good ones for all.
I bet if there was an advantage pointwise to using a classic type engine, they would be coming out of the woodwork....
« Reply #52 on: August 09, 2009, 01:36:42 PM »
Scott  there is an advantage to using them, however most contest do not award the points that are in the rules to give them.
Also I see theses engines all the time, unfortunate but many of them I see are in very bad shape, and new ones sell for a lot some times,  Ty's , and my point is the supply would dry up in no time if everyone used them.
« Reply #53 on: August 09, 2009, 03:53:26 PM »
If you don't get the points, then it's a DISADVANTAGE to use them against other competitors using the modern engines.If the points were given I bet more would be used. It's kind of like when Bill Wilson mentioned once at the Ringmaster Roundup that it was strange that he was the only competitor with a McCoy 35. He figured that that should be a perfect match for a Ringmaster as it was a fairly common combo back then. Sort of like taking a model T and putting a small block Chevy in it......no fidelity....
Offline Frank Sheridan
« Reply #54 on: August 09, 2009, 05:07:46 PM »
Before I go any further in discussion let me say that I myself have never competed nor have I witnessed many competitions other than doing voluteer work at the Lake Charles Nats. But one thing stands out among competitors in any sport - they are all looking for that edge that will get them an advantage over the other guy (or girl). I would imagine that it has always been this way, and truth be told, you would be hard pressed to find a "box stock" airplane or engine in competition today. So step back in time with X-ray vision with me to the flight line at a stunt meet back in the 1960s for instance. Take a look at this Nobler - the builder has obviously left out some structure to save weight, while this fellow made his rudder a little taller on his Nobler. Over here we have a Chief, but it only has one cockpit to save weight and drag. There's a Fox 35 that looks normal, but our X-ray vision can see a piston skirt mod or some grinding on the crankshaft. And this guy over here built his Smoothie with a larger than normal tail. My point is that nearly everybody throughout history competed with NON STOCK equipment, so zero tolerance for modifications in Old Time or Vintage isn't indicative of what existed in that particular period. And too many rules turn fliers into spectators. All this comes from a guy (me) that can barely do a lazy eight.
« Reply #55 on: August 09, 2009, 06:02:49 PM »
    I snipped most of the OP, since I mostly of agree with it. But I think it's very important to note that I have almost always used *bone stock* engines in serious competition, presuming you ignore adjustments like venturi size and compression/head shims. On my current engine (and the one I won the NATs with in 2006*) are/were *dead stock* engines, identical RO-Jett 61 BSEs. Same with the PA61 I used from 99-2003, and the OS40VF I used from 1988-1999 (and that was ONE individual engine). Going back even further, I also used box-stock ST46s, and before I flew my first contest, a box-stock Fox 35 (including the stock spraybar/needle). I haven't even had the head button out of the current engine. If someone asks me the head clearance, I would have no idea. Same with most of my buddies*.  And of course the ubiquitous 20PF that runs *absolutely perfectly* with absolutely no changes.
    I have had plenty of modified and "tweaked" engines, and modified some of them myself. I flew a local contest with a Larry Foster Stage III Fox (and beat David and his PA40, although we both lost to Bill Howe), but other than that, I have never found *any* advantage to the modifications or tweaks, and in almost every case (aside from Larry's engine) it has been *detrimental*. The idea that you need tweaked or "special" engines to be competitive in stunt is a huge misunderstanding -  and one of my pet peeves.
     The *vast* majority of the aftermarket tweaked engines I see are effectively ruined by the process, St51's with "reverse blowdown" that put out less power than a Fox 35, and LA46 tweaked to have less power than a Fox 35, and other engines that are so hacked up and poorly modified that they ate themselves up in a few flights.
   I won't completely dismiss the possibility that someone could do something useful - for example, the AeroTiger 36 is as good a stunt engine as I have seen, and Orestes made a very useful modification to the Discovery-Retro - but for the most part there's nothing you can do to a stunt motor to make it any better compared to the numerous dead-stock engines that work almost miraculously well.
*That's not to say we haven't used factory prototypes or semi-customs - Ted and David both won the NATs with 46VFs with AAC cylinder pistons assys from Randy, and the engine I used in 2006 could plausibly described as a prototype/custom (although you can call Dub Jett this evening and get an identical engine). Same argument with David's PA75s - first the 2-port version and now the 5-port "mail slot" version - could be considered prototypes or "factory works" engines. That's a little different from "modified" in my book, but I suppose it's a matter of definition.
Offline Bradley Walker
    • The Urban Rifleman
« Reply #56 on: August 09, 2009, 06:32:22 PM »
Just about every "stunt" engine on the market is based on a "modified" RC engine.
Many of the European "stunt" engines are simply design throwbacks to the 1950's and 1960's era engines in modern materials.
-George Bernard Shaw
« Reply #57 on: August 09, 2009, 06:39:52 PM »
    That's mostly true, although most of them aren't very good.  one of the only two really good ones actually uses a very important innovation that gets little credit or attention- the Retro "plug shield" definitely solves one of the big problems that plagued the ST60, i.e. collecting raw fuel and periodically blurping it onto the plug. Although Frank Williams seems to have been the first to correctly diagnose it and come up with at least one solution to it.
« Reply #58 on: August 10, 2009, 05:54:23 AM »
Well, schnuerles do that worse than baffle engines... especially when run rich (hence the blocking of the boost port).
BTW, the Big Jim ST 60's don't need that "plug shield".  I have never seen an engine run more symmetrically than a good Big Jim ST 60.  In fact, there is no more flawlessly running "stunt run" out there than Big Jim's engines (except for the McCoy 40 I suppose).  The compression numbers used by Jim are used by most if not all of the "modern" stunt engines, whether they know it or not (of course, I think he got his head design from the Merco).
One of the biggest issues is asymmetry (I believe you had similar problems?)....  breaking lean inverted and rich right side up (alsmot all engines do it when mounted inverted---even the 4 strokes).  The Russians finally gave up and went sidewinder.
« Reply #59 on: August 10, 2009, 11:54:14 PM »
      Not necessarily. Schnuerles with huge ports designed for R/C applications at 16,000 RPM sometimes have issues, for pretty obvious reasons. But not always.  Schnuerles with relatively small ports don't necessarily have problems.
   I am no particular advocate of blocking the boost ports. It worked OK in Dave's case because the lost power was more than compensated for by the fact that it was a 75 in an airplane that would have flown just dandy with an ST46.  Right now, he is running a better, and more symmetrical, engine with  multiple  boost ports, not just one.  My engines run dead steady inside and out, and it has the same 4 ports (2 regular, 1 boost, and 1 exhaust) everybody else's does.
    I think the area, shape, and angles make *far* more difference than how many there are. It depends on the particular design - as always the details are what matters, not so much the gross characteristics.
   Here's a conundrum not explained by your theory of boost ports - One engine with gross variation from inside to outside, the other with virtually none. Same very large ports, same number of ports, same compression, same plug, same fuel, the only difference was that one had a spigot venturi and the other did not. Oops! I misspoke, it's not just identical engines, it's *the same engine*, 10 minutes later after swapping venturis.    How did the boost ports change between runs?  I would conclude in this case that the problem was not caused by the presence of boost ports, nor cured by their absence.
     Huh?  Compression of a PA61 is the same as Big Jim ST60?  I was unaware of that improbable, uh, fact. And I certainly don't understand how engines ranging from 6:1 (GMA-Jett, early models) to 12:1 (40/46VF) can all match.  Or are we now back to claiming the VF "isn't a stunt motor"!?
   One of the things I *am* concerned with is that a lot of the 'blocked-boost-port-for-lucky-best-Stunt-Run' engines run nice and predictably, with reasonable symmetry - and absolutely no power. Same with several Iron Curtain "modern" stunt engines. I would think a currently-produced ABC 40, even a baffle-piston, should be able to out-do a Fox 35. But then I saw a bunch of them run, and they wouldn't. Stalker 40RE, run per directions, absolutely gutted out to the max lean, Top Flight 10-6, Nobler - 5.4 second laps, and absolutely nothing/sagging in the maneuvers. If I set a Fox like that, it would be going 4.6 right up to the point the crank broke. That's about 60% more power - from the Fox!  Well, it's just that one engine, right? Well, no, the same guy got two more of them, pretty much identical results. So, switch to a Double Star 40 - slightly better, but still not even close power-wise. You can fly a Nobler with some success with a Veco 19 - but not a brand new "Stunt 40"?  They're not all like that (the Rustler "Metamorph" is pretty strong) but a lot of them are.
     A lot of the mod-jobs are even worse  - 46LA "modified for stunt run" unable to get a Pathfinder ARF up to sufficient speed to attempt a wingover - even with a 10-7! At sea level and 50 degrees.  A stock engine with 10-7 would fling that thing around at 80 mph, and with a 12.25-3.75 APC it makes the airplane sit up and talk. But the modified engine came up about 2000 RPM short.
     If your point is that you would prefer a McCoy 40 to a super-gutless modified 46LA then I would not be inclined to argue with you.
    Of course, not all of the modified engines are like that, but I have seen enough of them that it frustrates me mightily. I hate to see people continuing to live in the same mindset as 1985 when we were always desperate for more power and living with 6" of pitch because the engine isn't strong enough to do any better.
But it makes absolutely no difference to me - if you can get a McCoy 40 to run better than you can a PA75, have at it. The results will provide confirmation of your theories, or prove them wrong. I am certainly not wedded to any particular approach and will switch in a heartbeat if I think it will work better.
    "Had" being the operative word. I have had no symmetry issues *at all* with the 40VF or the RO-Jett. Or the 5 flights I had with the 46VF (stock, I never ran the AAC version). I had a minor, but "close-enough-to-come-in-third" problem with that my Stage I PA61. It was symmetrical 95% of the time, but it was more powerful and provided better performance than almost everything else 100% of the time, so it was not a hard decision to run it.  That appears to have been conclusively solved by the Stage III from 4-5 years ago, or the two-port, or 5-port PA61/65. I am pretty sure that I would be able to notice such a thing pretty easily on the 53-oz. Vector 40.  Not a problem with the current PA75s that Dave runs, near as I can tell. I guarantee that if it *did* do that we would fix it or switch.
    I think the mechanism is obvious - if the charge shoots through huge ports with low velocities, then the acceleration along the cylinder axis has some effect on it. In some cases, that causes different scavenging from inside to outside. In other, maybe most,  cases, it doesn't seem to have any consequential effect.  Note that the same problem can happen with baffle-piston engines - Fox burp being an absolutely hallmark example, the tendency of the ST60 to stumble on insides (as discovered by Frank, and diagnosed/corrected by the inboard cylinder) being another.  Blocking the boost port, and thus cutting the port area by 33% clearly increases the charge velocity, and that's what changes or fixes the symmetry. Sometimes. However there is also abundant evidence that simply making the 3, or 4, or 5 ports smaller to get decent velocity will have essentially the same effect. As will running 4" of pitch instead of 6 (and thus increasing the shaft HP {far less efficient prop at normal level flight, same power into the airframe}, and increasing the flow velocity *that* way). The 4 vs. 6 part was what was missed by almost everyone during the schnuerle wars.
    There are also clearly other factors that appear to have nothing to do with the port size, number, or placement - like the venturi change example above. Or the fact that it is a serious problem if you run a conventional muffler, and no issue when you run the same engine on a pipe.
« Reply #60 on: August 11, 2009, 01:37:37 AM »
All this engine discussion brings me to this question - Is the Fox 35 or the McCoy 40 a capable engine by today's standards? Were these engines just "lucky" examples of the evolutionary chain that is engine development? Put a muffler on either engine and you've pretty much crippled them.
« Reply #61 on: August 11, 2009, 05:46:46 AM »
Well, uh...then get uh...pressure gauge and uh...check them.
Nearly all of the modern 60 ish "stunt" engines that are worth a crap range measure between 95 PSI and 110 PSI.  That includes the PA 61 and 65.  I have measured dozens of other engines.  Smaller engines have slightly lower numbers and larger engines have slightly higher numbers.
A ST 60 was originally designed for near 0% nitro and starts out at 125-135 PSI.  The Big Jim Modification made the ST 60 compression right at 105 PSI.  My PA 65 is right at 110 PSI when stock (with .024" of shims), and with a .010 shim added it ends up right at 105 PSI.  Same as a Big Jim ST 60.
« Last Edit: August 11, 2009, 06:25:35 AM by Bradley Walker »
« Reply #62 on: August 11, 2009, 05:52:48 AM »
I did not find the spigot venturi did anything for asymmetry.  Neither did Doug, Bob G, or Mike Scott.  So, your lab experiment has not been duplicated with the same results here.
No one I know, in fact, has fixed any issue with a PA with a spigot venturi except for you and your flying buddies...
Mostly what I see is everyone running the engine so deep in the 4 cycle that symmetry becomes a non issue.  If there is no break, there is no asymmetry...  that is why I think everyone runs so far away from the break, to get rid of the "charging on the outsides".
I have a video of the 1996 Nats.... when everyone was running the OPS 40 and the OS VF 40 and 46.  Typically round eight from that video...   burrrrrrrrrrrrr (inside)  neeeeeeeeeee (outside) burrrrrrrrrrrrr (inside)  neeeeeeeeeee (outside).
« Last Edit: August 11, 2009, 06:33:52 AM by Bradley Walker »
« Reply #63 on: August 11, 2009, 06:00:56 AM »
Why do you think I plugged the boost port in the first place?  In the "underloaded" state, with the large #8 Eather pipe and small "green" three blade prop, I was getting stumbling in insides and leaning on the outsides.  So I plugged the boost port, and it mostly went away.  It certainly improved.
Where do you think David got the idea?  I told Randy Smith and Brian Eather what I found and they told David...then he tried the two port sleeve that Randy never tested.  The rest is history.
« Reply #64 on: August 11, 2009, 06:06:37 AM »
Asymmetry is a tricky one.  Very tricky.  There does not seem to be a clear fix in any given case...  I even know of one engine running perfectly symmetrical, and then the next one bought (being supposedly identical) runs asymmetrical.
That is why the really smart guys finally gave up and went sidewinder.  Certainly works for the 4 stroke.  It is a completely different engine run on its side.
« Reply #65 on: August 11, 2009, 06:17:14 AM »
We fixed that.  Actually, EricV found the fix.
The DS 40 spray hole was way too small for a stunt engine.  It was teeny tiny, like for a combat engine run on a bladder.  Once the spray bar was replaced with a PA spraybar, it got balls galore.  When before it was lean and two cycling, now it would just drone along in a deep 4 cycle.  Fuel consumption went up.
Ask Fitton...   It only took a year of nagging to get him to change it in his Classic plane...  He he.  The change was *significant* and this modification was the only modification made.
« Reply #66 on: August 11, 2009, 09:20:48 AM »
I wrote an article for PAMPA back in the 1980's comparing the "cut" OS Max FP stunt engines to the Big Art style blocked boost port engines (my last technical article for PAMPA I can assure you).  I think the sentence that got me in the most trouble was the one that implied that the "cut engine" would not pull my Tutor through a wingover (so that is kind of ironic).  I hope no one starts a letter writing campaign for your comments.
I spent an entire year blocking boost ports and changing port sizes in my three OS 46 SF's based on the findings of the Adamisins.  The results were very interesting to say the least.  I think the effect of the port size is much more significant than timing (for example).  I had one OS 46 that I took all three ports and reduced them by half.  It would only run at about 7800 RPM, but it not 4 cycle and it needed a high pitch prop, and it would stunt at one speed...  it was really kind of amazing.  I was convinced by everyone at the time that I needed to be running a 4 pitch prop, so I switched back to the blocked boost engine.
PS:  I hate low blow down engines...  they are truly gutless.
Offline Dennis Moritz
« Reply #67 on: August 11, 2009, 11:16:22 PM »
In Philly we run stock fp40s and fp35s in stunt. A lot of them. Jack Weston won advanced a number of times on the East Coast, using one of these engines. Got the boot. Mike Palko ran an FP40 in Advanced, did very well, then went to electric. Modified engines have been down on power. Though we're still trying to make a few work. The stock engines are sensitive. A click or two of the needle can move you out of the sweet spot, which often means trouble. Needle them correctly, however, and you've got a strong 40 with a useful break. These engines should be adjusted according to flight performance. Ground settings may or may not correspond. Do not be ham handed on the clicker. Find a setting that flies quite rich. Than adjust one click lean at  a time on the ground. Always fly the new setting. (That's how I do it.) FP35s and 40s usually need a head shim or two to soften the break.
LA46s are great. More forgiving. Can loaf in a 4stroke or run a hard 4stroke and still provide a useful break. Extra head shims often help make the break milder. The La46s can even tolerate a variety of props. I was surprised (amazed) by folks running PA65s in Vector 40s, since I've pulled that plane around with an LA46 running in a wet 4stroke, too wet to even break. Plane went up and over with no problem. Even in a decent breeze. Why use a $400 powerhouse when an LA46 will do the job. So far the difference between inside/outside has not been a big issue for us. Jack's engines often ran slightly richer outside than inside. He found that to be a useful characteristic.
« Reply #68 on: August 12, 2009, 04:06:53 PM »
Well, way back in the early 1980s or so this "not really smart guy" was scratching his  head over the inside versus outside conundrum with the then popular side exhaust OS, .40 and .45 FSR schnerles  that Bobby Hunt had some success with -- winning the WC a couple of years before.(plus a handful of other similar engines -- OPS, K&B, and that pretty black engine with a gold head whose name escapes me in yet another oldtimer's moment)
Using my designed by a "not so smart guy" Imitation (built exclusively as a test bed for engines and for some very interesting fact finding [for a dumb guy] about flaps and airfoil testing) I "tested" a number of engines and essentially all of the schnerle ported ones exhibited the exact same characteristic.  Rich insides and two stroking outsides in maneuvers combining both postitive and negative g loadings.  Had me scratching my dumb head until -- from out of the blue, I guess, since a dumb guy couldn't have come up with an idea -- it occurred to me to experiment with some variations on the standard theme.
Because some gremlin had planted in my "not really smart head" the idea of a removable RC style engine mount with "nose moment" spacers to accommodate different weight motors for testing, it was easy even for a dumb guy like myself to modify the manner in which the engine was mounted ... and then go fly them to like, you know, test what happens when I did so.
I first mounted the engine sideways as your really smart guys did (remember this was way back in 1980).  Totally cured the problem ... well, not really.  What happened is it totally reversed the problem.  Now the engine two stroked in insides and went rich and stumbled in the second outside of the figure eights (by the way, this dumb guy noticed that the lean/stumble in insides versus outsides only happened in figure eights.  There was no significant difference in the engine run in simple inside/outside loops and, further, shimming the tank to try to undue the "schnerle" thing had essentially zero effect even if done to the point that upright and inverted flight laps were dramatically different in predictable response to the tank's relative height to the engine.
Alas, my single bright idea for a dumb guy had proven a failure.  Fortunately, however, the little gremlin came back and suggested that I "test" some other solutions that I, as a dumb guy, wouldn't have been able to figure out on my own.  I now rearranged the engine mount so that the cylinder was mounted at 45 degrees between sidewinder and inverted.  Then I went back out and, despite my relative lack of intelligence, "tested" it yet again.  Oi vey.  It ran essentially exactly like it ran when side mounted ... the reverse version of the identical rich/lean conundrum.
Now, a really smart guy would probably have given up and gone back to the McCoy .40 but, not being so bright, I took it one step further.  I rearranged the mount to set the cylinder at 22 degrees from inverted and actually "tested" it some more.  By George, despite my stupidity and the need for a gremlin to force me to "test" some ideas, the engine ran like a clock.  Absolutely zero "Schnerle" effect in either direction.  It was stunt engine Nirvana.  My God, that Gremlin must have been a genius!
Well, again, not exactly.  I foolishly thought it would be a good idea to test the redundancy of my discovery.  I bolted on an apparently identical .46 FSR and reran the "tests". Double alas, "tests" on this engine at  22 degrees ran exactly like it did when fully inverted.
Well, even a dumb guy learns eventually and I shelved the project.  Too much "testing" for a dumb guy ... so I decided to try something else instead.  I started "test" flying four stroke engines.  This was around 1983 and was successful to the point that I built an airplane for the Enya .46 4C intended for the 1985 Nats.  The tests that were so successful with the Imitation were less so with the new airplane so it was re-engined a couple of times ... first with an FSR that once again failed to live up to expectations and then with a venerable old ST .46.  It won the Walker Cup in 1986 with the Tigre.  I guess even "not so smart" guys find an acorn from time to time, huh?
All I can say is it is really great that after all these years we finally have a "really smart guy" like yourself to make up for all the years of PFM development done by the not "really smart guys".  Here I thought I was testing all that time and it turns out that I wasn't smart enough to do so.  Thank heavens you've straightened me out.
Ted
« Reply #69 on: August 12, 2009, 05:11:45 PM »
Ted
Ted, it amazes me to no end how everything that I (or it seems anyone who might have a differing view) say or write is turned around to be a personal insult to you or one of your friends....  It seems every discussion is all about you, no matter the subject.
There are literally thousands and thousands of stunt fliers worldwide out there, Ted.  Many of them are doing lots of things that *you* do not do...  At the same time, no one here is discounting your findings or the success of your methods, quite the contrary.
In fact, there was nothing, absolutely *nothing* insulting to you or anyone else in any of my posts...
It really is no wonder that stunt design, or particularly stunt design innovation has nearly ground to a halt in the last few decades, and most particularly in the last decade with the introduction of Internet forums.  Young stunt designers are nearly non existent.
Any discussion of leaving the "norm" is quickly shot down with the obligatory "this has won XX Nats, and XX WCs blah blah", or the argument is quickly reversed to "are you saying I do not know what I am talking about?" (since one might be implying that they might not use the "proven" method)....  or God forbid, someone that has not won the Nats has thought of something original that might be of use, or even profound.
I doubt the Yatsenkos could have developed the system that has dominated the Nats for the last few years (and is slowly taking over all over the world), if they had been inundated with this "follow what the elite tell you is *right* do or be beat into submission" culture, where thinking outside the box is downright discouraged (unless you are buddies with the elite of course...  then it is innovative).
PS:  I think your post would have been great minus the copious disdain.  I did not remember your tests.... which are interesting.
« Last Edit: August 13, 2009, 05:48:10 AM by Bradley Walker »
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #70 on: August 12, 2009, 06:03:54 PM »
I fixed a ST 51 that would all but quit on insides by going to 20% oil instead of 22%  ;D
« Reply #71 on: August 12, 2009, 06:31:34 PM »
Weird, Jack Weston's inverted fp35 runs rich outside... a bit.
Online John Miller
« Reply #72 on: August 12, 2009, 07:02:58 PM »
Well, despite all the stuff on engines and such, I still think that a well built Nobler, powered and trimmed well, will still compete at the highest levels, with the possible exception of Open at the Nat's.
I use the Nobler for my example, but there are many other designs who will also perform to this level.
Online Matt Colan
« Reply #73 on: August 12, 2009, 07:37:06 PM »
I agree John.  If Ted Fancher came with a nobler and placed high at VSC with not much trimming from what I've heard.  With a newer power source, I think, once again from what I've read, any good flying classic plane could place at high at the Nats.  I keep saying this is from what I've read and heard because I don't have enough planes built, done enough, if any testing with planes and engines.
If I built a USA-1, I'd power it with a Shneurle ported engine (PA, RO-Jett, OPS, VF etc.) for more power, that way it could power the plane through the pattern easier than an ST 46.  The guys back then built planes with the power they had available.  That's all Bill Werwage, Bob Gieseke, and George Aldrich had for motors back then.  Bob Gieske was competitive with a Geiseke Nobler and a Fox 35 right up into the 80s.  His last Walker Cup win was 1979, when Billy W. had the USA-1, les McDonald also had his Stilletto and Bob Hunt had his Genesis 46's.
Thinking out loud here, and forgetting a couple things to say then remembering it a minute later is what this post is.
« Reply #74 on: August 13, 2009, 06:17:35 AM »
From Stunt Minimalism:
"I know for myself, I have been nothing less than shocked about the performance of classic era equipment in modern times.  In the last year, I attended two contests.  In both contests the two best running engines I saw were both McCoy 40’s.  You simply could not make a better performing stunt engine, in my opinion.  A manufacturer could make an engine that would last longer, or put out more power, but I do not believe that the quality of run has been improved upon since the McCoy 40.  There I said it…"
In determining "quality of run" I look at run symmetry, consistent break, torque, line tension, penetration, and wind up in the wind performance.
« Reply #75 on: August 13, 2009, 07:50:52 AM »
As a participant and designer spanning the Classic through modern era's I have witnessed many iterations and variations in CLPA design & power approaches have been used - both successfully and unsucessfully - at different times.  I'll allow that I have my favorite ideas - and unfavorite ideas, but I am hard-pressed to catagorically praise or condemn any approach.
Surprisingly few anayltical tests series - like Ted's Imitation article - have been done AND published.  Very few tests have applicability beyond a narrow range of applications.  Thus we are left to hack & whack and pronounce the good ones as intelligent designs and the bad wones as... crooked or underpowered!
BTW, I do not recall ever seeing Ted's experiments with engine positioning before.  That is good stuff too.
For my part I designed roughly 17 birds over a 17 year span that all used the SAME power system.  Most these were (for their time) relatively successful designs, a few were truly exceptional.  A couple would have clearly benefited from power-ups, almost all would have bnefited from weight reductions!  As a result I concentrated on airframe aerodynamics and efficiency, and I think I learned a lot along the way.  I am also distrustful of the crowd who believes that more power is ALWAYS ALWAYS ALWAYS better.  I mean, you can put a candle in a cow-pie but that don't make it a birthday cake!
If instead of standardizing on power I had "led" with power systems, I am sure my aerodynamic design "formulas" would have been different - and I would have learned a lot - likely dfferent - lessons.  In modern times, we can buy 60's built in the same blocks as 40's, and can buy 75's that weigh the same as a 46, it is easy to be seduced by the "larger displacement".  The ability to tailor that displacement to deliver the power required for the airframe is where the hard work comes in.
In 1979 Bob Gieske won the NATs with a Fox 35 (at least 10 years obsolete) in some of the WORST wind ever encoutered at a NATs final, and did it against 4 "state of the art" power systems and airframes.  This strongly suggests that even "underpowered" Classics used to fly well in the wind, and that in the final analysis, PILOT skills and preparation rule.
All I suggest is that we all "chew" on this before making blanket statements about the "clear superioirity" of one design approach versus another.  Sacred cows make the best burgers...
Offline billbyles
« Reply #76 on: August 13, 2009, 08:12:22 AM »
Brad, I think that a large part of the problem is that for a very intelligent guy you seem to have no idea how you come across to others.  You make these long statements about a subject, then when others disagree you "wrassle" with them verbally until they just get tired of going back and forth.  While others still may not agree with you they simply realize that you aren't going to quit until they either agree with you or let you have the last word.
Bill Byles
AMA 20913
So. Cal.
« Reply #77 on: August 13, 2009, 08:23:01 AM »
As I have stated before will do again.  What works for one may not work for someone else and vice versas.  DOC Holliday
« Reply #78 on: August 13, 2009, 08:23:41 AM »
I don't mind anyone "disagreeing"...  but God LORD that is the problem, NO ONE IS ALLOWED TO DISAGREE WITH THESE PEOPLE!!!!
I certainly have not been the one with my hackles up...  no sir.  I am just stating my side.  I have made no derogatory remarks about anyone else (or their methods) until now, and the only reason is that I am just sick of it, frankly.
As far as what *I* say and write, I seem to do quite well.  I think that my articles in Flying Models and Control Line World have been quite well received, and I have never received one single negative comment about my ability to relay my thoughts.
No, Bill I think the friction might be coming from some other people's inability to communicate effectively.  The same people you are never allowed to disagree with, in fact.
Online John Miller
« Reply #79 on: August 13, 2009, 08:26:52 AM »
Yes,, the McCoy .40, heck, even the .35 were,, and still are, the best engines of their time when it comes to quality of run. Because of certain problems in QC, and in the way some pilots lack of understanding on how to run, and care for them, they were often maligned.
If I was to put together a classic ship, trying for the spirit of 64 award, and wanted it to be competitive, I would build a Southwick Lark. I would indeed power it with a McCoy .40, one that had passed through the hands of Tom Lay, because he does something to the piston that allows a muffler to be used. I would use a totally modern control system, but everything on the outside, I would try to use from the day. Veco streamlined wheels, Veco or Froom spinner, Top Flight prop, Silkspan and dope.
I'm thinking such a setup would be devastating in the hands of a very good pilot, like Whitely Gordan, Byles, et all. I'd even wager that such a set up would do well in PAMPA Classes within certain conditions,agianst modern equipment.
Edit
While Ed's Lark is a beautiful design, most would say that the Sky Lark was the better flier. I agree, and admit that I mixed myself up above, and meant to say Sky Lark rather than Lark.
« Last Edit: August 13, 2009, 10:29:22 AM by John Miller »
« Reply #80 on: August 13, 2009, 04:23:43 PM »
Don't mind disagreement one bit, Brad.  Quite the opposite, in fact.  Nobody enjoys a spirited exchange of ideas more than me.  I’m more than willing to do so and, ultimately if necessary, amicably agree to disagree regarding a difference of opinion … and have done so many times in the past.
It's the name calling and sneering disdain with which you reference others and their ideas that is a turn off.  To wit, I find pretty much every one of your characterizations of yourself in this post to be, frankly, laughable; an absolutely perfect example of pots calling kettles black.
Your manner is caustic to the extreme; distasteful in tone; and disrespectful to those to whom you refer.  People pretty much reap what they sow in this world and you are nothing if not an adept spreader of your seed.
Ted
Offline Richard Grogan
« Reply #81 on: August 13, 2009, 04:39:00 PM »
Since I wasn't around to see how they flew in competition, how do some of the older stunters, like a Chief or a Smoothie compare to the latest greatest designs as far as capabilities of the airframes in maneuvering? Are the new planes much better flyers, or just differently styled and constructed? If a flier were to install a modern powerplant on an old design, could it be a competitive ship?
Original Topic
Long Live the CL Crowd!
                  AMA 85745
« Reply #82 on: August 13, 2009, 06:30:17 PM »
Original Topic
Richard - spoilsport!!!  LL~  LL~  LL~
Frank: Of course Richard is right to refocus back to your original post.  The answer is that even in their prime the Chief and Smoothie were not NATs contenders, so it would be hard to put them in that position today - even with modern power.
Ask my dad what the best stunt trainer is and he will recommend the Chief in a heartbeat.   According to "legend" GMA built several Chiefs as precursors to designing the Nobler.  Indeed even today the Chief is a terrfic flyer and corners like crazy - but that big hershey bar wing can become a handful in the wind.
I cannot say I ever saw a Smoothie fly as well as a Chief, don't know if it can or cannot, but that is just my observation,  Thus MY choice between those two would be simple.
As for Best of the old versus Best of the new I'd say ---- not a lot of difference in calm weather, but a big differnece in the way flyers contend with adverse wind - tho not necessariy the success.  With the old they tended to richen up and fly the wind.  With the new they tend to try to go fast and over-speed the wind.  Each approach has its proponents, its rewards and its adverse consequences...
Online FLOYD CARTER
« Reply #83 on: August 13, 2009, 07:04:07 PM »
As predicted, this thread has become one all about "rules" , "judging", and competition issues (winning strategy).
Now, to the original question:
Some older designs are being flown in modern PAMPA events, but at a handicap.  The older models actually have their own flying class:  it's called "OTS".  Within that category there are some good ones and some real dogs!  So, it isn't fair to generally mix the older designs with the new and expect similar results.
An early response suggested that "barn door" wings are hard to handle in the wind.  And another person wanted an accurate definition of "wind".
I both agree and disagree with that premise.  I've flown a Coasby Taurus that was all over the sky in the wind.  My "pollywog" Chief (another barn door with flaps) takes the wind in it's stride!  My WILDMAN 60 (a large plane- picture enclosed) laughs at the wind and bores on regardless.
Online Matt Colan
« Reply #84 on: August 14, 2009, 07:29:54 PM »
Back to the engine thing.  Paul Walker built a Cobra and he powered it with a Fox 35, adn brought it to a win at VSC.  Engines may not make as much of a huge difference as everybody thinks, but some planes could use a larger engine.
« Reply #85 on: August 15, 2009, 08:33:38 AM »
As a wrote in Stunt Minimalism I do believe there are certain people that benefit from technology, but I would also argue, at the same time those people DO NOT NEED TECHNOLOGY TO WIN.  They would win without it.
From Stunt Minimalism (referring to the example of disc golf minimalism---the basis of the philosophy):
1.The level of technology needed to perform well is actually very low.  Avoiding faddish technology allows the player to fully evolve as a competent player.
2.The average player is constantly being inundated with alluring new technology that statistically will not improve their games.   This is easily proven by taking a student into a field and throwing high tech discs next to low tech discs and marking where they land.  It takes no time at all to see that the high tech discs often worsen performance despite the promise to the contrary.
3.The best players developed their skills using low tech equipment.  Most of the competent players in the modern era actually developed their games using very basic, low tech equipment that changed very little for years and years (even decades in some cases).
4.The best players do not rely on technology to dominate.  They do not need too, they are the best.  See #3.
5.Every piece of equipment has a specific function.  Learn how to use it.
From Stunt Minimalism (as it applies to stunt):
The level of technology needed to perform well is actually very low. The ugly truth is that control line flying stunt is *not* a high tech game.  It simply is not.  It never has been.  In fact, the modern pattern, which is flown at 55 to 60 mph, has not changed in 40 years.  As a result, the baseline requirements for the equipment required to successfully fly the event has not changed one single bit in that entire time.  In my experience, I cannot say that the equipment/pilot paradigm has shifted radically into the modern era.  Does the modern stunt ship fly “better” than the classic or Super Seventies era stunt ship?  I am not so sure… in fact, I believe there might be ample evidence to show the contrary.  Just watch the top pilots flying their Classic competition planes if you want to see for yourself.  I could assert that Billy Werwage flew his ST 40 powered Vulcan better than any plane he ever built.  In fact, Bob Geiseke accomplished more with a Nobler and Fox 35 than he did with all the other designs and equipment used since.
I know for myself, I have been nothing less than shocked about the performance of classic era equipment in modern times.  In the last year, I attended two contests.  In both contests the two best running engines I saw were both McCoy 40’s.  You simply could not make a better performing stunt engine, in my opinion.  There I said it…  A manufacturer could make an engine that would last longer, or put out more power, but I do not believe that the quality of run has been improved upon since the McCoy 40 (in determining "quality of run" I look at run symmetry, consistent break, torque, line tension, penetration, and wind performance).
The average player is constantly being inundated with alluring new technology that statistically will not improve their games.  I know of several people who have switched from the large 65 and 75 powered pipe planes to smaller classic era planes with a modern, slightly oversized engines and their flying improved and there consistency greatly improved.  I am sure it would not be all that unusual if those same people were to meet up with a stranger from out of town that they might hear “wow, you'd be really good if you had a 75 powered pipe plane!!!”  If someone tries to tell you that you *must* have XXX piece of gear to compete, you might be best served to just turn on your heels and walk away .
The best players developed their skills using low tech equipment.  Many of the top modern stunt flyers had decades of “Stunt Minimalism”.  Many of the top flyers competing today spent years and years flying simple to build, inexpensive airplanes with very basic finishes and low tech power plants.  Many flew kit planes or modified kit planes with simple dope finishes, had one kind of fuel, a 1950’s era designed engine, and flipped their wood propeller with a naked finger.  Yet, many of those same flyers will tell up and coming pilots that they need a 750 square inch 19 point airplane, a $400 engine, a $50 prop, etc to “move up”.  Today, we are very fortunate that there are many good ARF and ARC alternatives to get people flying a lot of aggressive practice.  If you are at that stage where you feel you are ready to really improve, or if you are afraid to fly in bad conditions or low to the ground, I really suggest that you build yourself three identical ARF's this winter and fly them until they are worn out or until you crash them all while flying in 30 MPH winds.  The lack of effort in the building of an ARC or ARF can greatly offset the fear factor in practice.  Nothing will make a pilot more “gunshy” about flying aggressively than a new, perfectly finished, $1500 airplane.  Although it might go against conventional wisdom or tradition, I think many pilots go to “pretty” planes too soon in their stunt careers (I know I did).  As a result, they learn to fly “timid” or even “afraid” (certainly not relaxed) because their main focus becomes protecting their 18 point beauty rather than being able to practice with four foot bottoms in 20 MPH winds.
The best players do not rely on technology to dominate.  The idea that “so and so hot shot flyer” won XX number of contests with this YY technology speaks more to the ability of flyer than it does to the technology.   Most of the top flyers have won with many different kinds of technologies.  In fact, some of the best flyers use unproven equipment just to say they “did it first”, not because it is the best equipment available.
Every piece of equipment has a specific function.  It is extremely important to clearly define the goals of the equipment and *understand* how it works.  Truly understand it (read that again).  I can relay a story about myself that might demonstrate what I mean.  The last few years in my stunt career (I am actually in competitive hiatus) have largely been exploratory in very specific ways.  I have been trying to understand more clearly “why” some stunt equipment combinations work, and others do not.  As a result, I certainly found many combinations that worked very marginally, most all of my own design (ha ha).  None have been the “magic bullet” that I was looking for that would catapult me to world domination.
I think many of the opinions bantered about as technical discussions are really just self promotion.  Effective self promotion may be the most powerful piece of equipment there is...  If someone can effectively plant the idea in a judge's head that it is "impossible* for XX to compete with YY in "serious competition", it will effect the outcome.  There are people who do this...  in front of judges.  I have stood right there and heard with my own ears...  at every level.  I hear it at local contests, I heard it at the Nats, and I heard it at the WC's.
Competitive stunt flying is a sport, and certainly has no immunity from this “you *must* have a certain level of technology to be competitive” idea.  This sentiment is bantered around a lot in stunt circles (many times within ear shot of current judges or future judges).  I am not a big fan of this practice.   Admittedly, this is a pet peeve of mine, as I have never been much of a fan of the “elitist” aspects of stunt.  The idea that a contestant must conform to the “in thing” to be accepted or have the judges “buy” a performance by meeting some ancillary pre-requisite requirements has always been the thing that I disliked about stunt the most.  I feel that this type of elitism is poison to all judged sports and should be purged at every opportunity…but that is another discussion altogether.
« Reply #86 on: August 15, 2009, 01:54:24 PM »
Quote from Brad's Minimalism article: "Competitive stunt flying is a sport, and certainly has no immunity from this “you *must* have a certain level of technology to be competitive” idea.  This sentiment is bantered around a lot in stunt circles (many times within ear shot of current judges or future judges).  I am not a big fan of this practice.   Admittedly, this is a pet peeve of mine, as I have never been much of a fan of the “elitist” aspects of stunt.  The idea that a contestant must conform to the “in thing” to be accepted or have the judges “buy” a performance by meeting some ancillary pre-requisite requirements has always been the thing that I disliked about stunt the most.  I feel that this type of elitism is poison to all judged sports and should be purged at every opportunity…but that is another discussion altogether."
Brad,
I very much agree with a great deal of your minimalism article.  I think my only serious disagreement is with your belief that fliers that won't necessarily profit from whatever is "high tech" at a given time feel compelled to buy the stuff because they have been talked into doing so by self aggrandizing elites. Quite the opposite, in fact. I believe that efforts (by Brett, for instance) advocating lo tech approaches with the FP .20 and the Sig Skyray (which has been very effective, by the way) fall neatly into the envelope you're trying to fill with the minimalist approach.
In addition, if you'll go back in this forum a ways you'll read where I unequivocally  state that some of the best patterns I've ever flown have been with very good designs from even the earliest parts of the classic era.  Noblers, Chiefs, Chizlers, etc.  I then go on to make a case for why I feel we have made progress in design and power (though specifically not including bigger size) which allows good air equivalent performance under more adverse conditions than was possible with the earlier good designs.  I'm perfectly willing to accept the fact that you don't agree with that belief thought and we'll just have to agree to disagree as to whether there has been any progress in stunt design since the '50s.
I just don't think I've seen any significant attempt by anyone who might remotely be considered "elite" to force feed modern technology to those who aren't ready to utilize their benefits.  This is America, however, and such admonishments have little bearing on whether those same people will or will not avail themselves of the opportunity to buy beautiful, nearly custom made pieces of modeling jewelry whether or not they stand to benefit from it from a competitive or self-improvement standpoint.
I go back to your comments about golf, etc. and the apparent rush to "buy a game" by using (ostensibly) what the pros use.  In my opinion you misinterpret the reason both golfers and stunt fliers rush to the "holy grail" of the day.
I would prefer a comparison to automobiles and their fans.  There is a panache associated with possessing something that is state of the art, aesthetically pleasing, has the capability for great performance and, yes, turns heads when it passes by.  Possessing such a thing (or wishing one could afford to) doesn't for a minute presuppose that that person expects to suddenly win road races simply by virtue of owning the thing.  I love to drive Shareen's 650I but don't for a minute even pretend to take advantage of the performance of which it is capable.  Sure, I drive it with a bit more verve than I do the Town and Country but I've no pretension of being capable of using it to its capacity.  And I'm perfectly happy with it that way.  In addition, I love to simply look at it; wash it; wax it and generally take delight in its mechanically breathtaking beauty.
I'm of the opinion that the popularity of "state of the art" stunt equipment is 95% related to the automobile analogy. I believe easily 95% of the people that love stunt do so not because they think they're going to beat Paul or Bubba or Windy on a given day but because the tools of the event have the same panache and thrill of ownership as the Ferrari or BMW of their dreams.  The differences are twofold:  First, with a little budgeting they can afford it; Second; the barb on the end of the hook that holds "also ran" competitive adherents to the event for a lifetime is that, with their own two hands, they personally add more than half of the appeal of the object themselves.  They make something beautiful that ... even if not a likely Walker Cup or WC winner in their hands ... has the potential for being that good.  They love to look at it.  They love to fly it.  They love to wipe the oil off after a flying session.  And they love to think that if Dougie was flying their little piece of perfection, it could win the Nats.
That is a special relationship to a "thing" that few other endeavors allow at a price the majority of us can afford.
Bottom line for me:  I don't think 10% of the people that buy the stuff you're talking about do so for the reasons you suggest... i.e., because some hot shot said they're nobobdy unless they use it.  I think they do it because they want to be associated with something special and this is where they chose to do so.
Ted
« Reply #87 on: August 15, 2009, 03:46:13 PM »
I am not sure that I said that we have not progressed since the 1950's...  in fact, I am positive I never said that.
I believe that people can be "convinced" (yes, oftentimes by peer pressure or marketing) into "progressing" too soon into equipment in which they have invested too much time, money, love, etc, and it adversely effects there progress as serious stunt fliers.  In other words, they have too much glue, contest grade balsa, inklines, 12 oz of glossy paint, hours and hours of buffing, an Al Rabe detailed canopy, and a $500 motor spinning a $50 prop in their whiz bang stunter to get really good flying it.  This is why I say many of today's stunt pilots flew simple models for many years, if not decades, before they advanced into the "high tech" stunters we have today, and it made them better flyers.
Years ago, minimalism was "forced"...  of course, no one knew it.  It only appears that way now, looking through the prism of history.
Brett's Skyray/FP 20 is indeed minimalism, I would think that would slightly more of a trainer, but the point is the same.  Get something you can build easy, build a lot of them, get going, and fly fearlessly.  You will get better.   You can learn to buff later.
« Reply #88 on: August 15, 2009, 09:57:12 PM »
Once again, Brad, we'll have to agree to disagree. I just don't see the negative aspects you do regarding the decision by stunt fliers to pursue the use of "state of the art" equipment in their personal stunt endeavors.  I think the driving force to do so is better explained by my analogy to exotic cars and the satisfaction the individual gets from having such equipment in his/her personal arsenal ... whether they are capable of utilizing the advantages therein or not.
Re the Skyray/FP20 combo.  I've seen and judged 500+ point flights out of that combination with (as you so correctly point out) a good pilot on the handle.  It is equally true that many of the fliers you feel are overreaching with their "all the bells and whistles" ships could very likely score better with the Skyray/FP combo because of the comparative ease of trimming it to fly to its optimum level and the almost turnkey run available from the box stock FP.  Yeah, it won't win the nats or a WC but, in the right hands it can be competitive in many expert level stunt events in various parts of the country.
It is sort of the ultimate "minimalist" approach to getting about 90% as good at stunt as an individual is likely to get.  The last 10% is the hardest.
I think, perhaps, where you are taking the wrong turn on this business is the assumption that the people that fly stunt all have the goal of winning the big ones.  After a lifetime of spending large parts of my time with stunt fliers I don't believe that is the bottom line for most of them.  I think its the Ferrari thing combined with the recognition that so much of what they value in the event is the artistry and talent they personally bring to the overall enterprise ... not just the hardware handed out at the end of the day.
Ted
Online Howard Rush
« Reply #89 on: August 15, 2009, 11:14:44 PM »
"I think its the Ferrari thing combined with the recognition that so much of what they value in the event is the artistry and talent they personally bring to the overall enterprise ... not just the hardware handed out at the end of the day."
And appreciation for the artistry and talent of the other participants.
« Reply #90 on: August 16, 2009, 06:34:59 AM »
A 650i, wuzz that? Shareen's high zoot washing machine(?) and why would Ted be polishing that. I know, I know, that's a very sexist idea, but it popped into my head. Please excuse my need to confess. Googling the Net corrected my male chauvinist assumption. A 650i is a curvy, very purty $80,000 BMW automobile!
Seems to me that Ted has had a hand in Stunt Minimalism over the years. Fancherized Twister, Imitation, Doctor, to name a few minimalist birds.
Actually most of the folks I know are versed in stunt minimalism. Arfing it up with Vectors, Cardinals, Orientals and the like, using LAs, FPs, Brodaks (when one can be had.) Cheap stunt, cheap fun. Good enough for Advanced competition on the East Coast. Most builds from scratch or kit are similarly functional, fun and well within the envelope of stunt as we know it. But it's nice to be reminded that the comparatively commonplace stunt artifacts often work well. PA envy can be a profound psychological problem. No doubt though a few in our circle exceed the minimalist and achieve (and enjoy?) more. Dan Banjok's Vista, Mike Palko's new 'lectric Mustang, and Joe Adamasko's various museum quality Spits and things, come to mind.
Seems to me there's another branch of Stunt Minimalism not mentioned as yet. Electric powered profiles, ARFs and the like. A new member of our club showed up with a Brodak Super Clown electric. The retread proceeded to knock out recognizable corners and decent eights. In a few short weeks he was flying an o.k. pattern. A year later he took second in Intermediate at our Philly Flyers yearly comp fest. Not bad. His stunt instrument, a kit bashed Banshee (uglier than stock) with sort of Fancherized moments and adjustable trim. The Chinese (cheap) electric power pack was the minimalist factor that put the system over. His electric approach means repeatable, controllable, power.
As far as Brad's view of peer pressure in stunt, yeah, I agree. Philly Flyers tend to sit in fold up chairs watching bits and pieces of flights, yakking it up, volunteering barrages of advice about recent flights, male female relationships and the current political distractions. Of course much of this is irrelevant to the task at hand, whatever that might be.  I count myself lucky to find friends as good as these. Sure cheers my mood. Not much pressure, however, to buy upscale components. Alas. I fear it's another example of our deficiency in intestinal fortitude.
Re: Old stunters vs. new ones
« Reply #91 on: August 16, 2009, 08:53:18 AM »
Ted
Ted, I just think we are discussing the two sides of one coin, not a disagreement just a perspective difference.
Minimalism is directed at those who truly want to get better at flying.
I understand what you are saying.  I believe you are discussing the attraction for many that enjoy the idea of stunt modeling.  You are saying people like owning a Ferrari.  Its cool to have a Ferrari, but I am not sure I would want to take my Ferrari to the local speedway and bump it around in a road race....  at least until it was pretty old.
The truth is that I could build a car for far less money, time, etc that would out perform a Ferrari.  If I were looking for track time to get better, that might be a better choice.
Minimalism oftentimes does not apply to the truly advanced modelers in our sport, although I could make the case that the best pilots could beat most everyone without all the bells and whistles....  and once again a large part of that flying talent of our most of our advanced flyers was developed using very simple systems.
« Reply #92 on: August 16, 2009, 10:46:21 AM »
There you go, Brad.  I can live with that. y1 y1
Ted
p.s.  The Ferrari thing is more the combination of superlative design, aesthetics and performance plus the nearly "untouchable" nature of it ($$$$) than the desire to beat it up on the race track.  Maybe a Playboy centerfold is an even more appropriate example (simply replace "Ferrari" in the above sentence with "Playboy Centerfold" and savor the thoughts that follow)
Just another example, I expect, of us approaching the subject from different points of view.
Eric Viglione
« Reply #93 on: August 17, 2009, 01:16:23 PM »
I think I have an analogy that may help... bear with me...
When someone tells me they want to learn photography, I tell them to get a Pentax K1000, and a 50mm stock prime lens. Nothing else. This is a fully manual camera, a great normal perspective lens, and it forces them to learn WHY things work the way they do. Learn to take pictures with it, until its second nature. Don't buy another thing until they have it down, and can grab the camera and capture a good picture, making all the needed manual adjustments without even thinking about it. Then, and only then, will I tell them it's ok to buy a flash. Same thing, learn to use it, etc. Then a tripod. Then we talk about composition, rule of 1/3rds, etc. Then I'm done with them and push them out of the nest. At this point they can purchase and add whatever they want, filters, a zoom, a wide angle, autofocus camera with a film adv motor drive, a digital camera, what ever.
The basic premise here is to force them to learn the craft, get an eye for photography, have the mechanisms and understanding of the basics of capturing light become second nature, BEFORE becoming an equipment junkie, which can sidetrack someone from  really learning the basics or ever becoming truly great at it.
I think Brad was trying to make a similar parallel that could be said for stunt...
My .02
EricV
« Reply #94 on: August 17, 2009, 01:56:31 PM »
The other day, Shawn Cooke, age 14, made what I think is a remark relevant to this thread. He said something like that guy needs to fly Ringmasters, referring to a fellow flying a dedicated stunt bird over cautiously. For one thing, flying sport planes, encourages flying in less than ideal wind conditions. A situation that will no doubt be encountered during a given contest. Shawn has been flying all kinds of planes for years. Sport profiles, mouse racers, ARF, kit built and original stunt planes,1/2A sport planes, 1/2A and .15 combat wings. He's been flying in stunt competition the last two years. I believe that flying the wide spectrum has aided his confidence and adaptability. The results are obvious. Shawn was just booted out of Intermediate after winning three or four local meets and coming in 2nd at Brodak.
Dan Banjok and Mike Palko also put a lot of time in with fun models. I believe this has contributed to their boldness in competition when the weird (and high) winds blow.
Offline Neville Legg
« Reply #95 on: August 17, 2009, 02:21:54 PM »
As we say in England "Hear hear" !! Years ago my guitar teacher used to turn up with a 5 bob (about 50 cents? I think)  nylon strung toyish guitar, and I still couldn't get my £100 guitar to sound anywhere near as good!.
P.S.  I have a Tom Lay modified McCoy 40! I didn't know they were that good? I'm looking forward to putting it in a classic model. I enjoy classic models!!!!
Cheers       Neville
(not) Descartes
« Reply #96 on: August 17, 2009, 02:53:49 PM »
Keerect.
Online Matt Colan
« Reply #97 on: August 17, 2009, 03:35:58 PM »
Congrats Shawn, looks like I may have a someone my age to fly against now, gotta get the Ares out AP^ H^^
« Reply #98 on: August 21, 2009, 04:31:52 PM »
Damn, some kids are just smart, aren't they.  The biggest problem I've seen amongst stunt flyers is that they haven't flown enough, they haven't flown enough different planes, haven't flown through enough problems to know what to do when the slightest thing goes not quite right. Too much time flying a beautiful planes very cautiously.  I'd bet a buck that there isn't a national or world champion that didn't start out flying clunkers, crashing and fixing until they learned how to fly, before they went on to the pretty stuff.  Dan and Mike certainly have put in a lot of time with less than perfect planes to prove the point.
« Reply #99 on: August 21, 2009, 05:22:03 PM »
Hmmm,
Phil,
I don't know about any other National Champions but from my very first airplane (a Veco Tomahawk with a McCoy Sportsman .29 on it) I've done my very best to make each and every plane I've built as attractive as I was capable of doing at the time (this included combat ships as a kid until it became obvious it was an exercise in frustration ... at which time I quit flying combat rather than take time building strictly utilitarian equipment).
Once again, I think it is too often not recognized that the reason a great many stunt fliers got into the event was because of the airplanes and the artistry involved in doing the stunt thing well ... not simply the drive to excel flying.  I think the excellent flying follows naturally because the pattern itself is a form of physical artistry as well which appeals to the same instincts.
Certainly not everyone, but my guess is that there are probably a lot more World and National Champions who shared my approach than the "fly beaters until you're ready to win" approach.
It is an interesting point of view,, however, and I hope some other guys that have been lucky enough to win a Walker Cup or two will respond as well.
Ted
