Define "good combat .35"...and "good" by whose standards?
I was associated with two rat efforts. Pilot built the first one (Hooptee) and I built the second, an original. I don't recall if I named it or not, but seems likely. "Dirty Rat" or something like that is probable. But we used a K&B .40 (which are cheap and easy to find at swap meets, and RJL might even have some parts). The Hooptee did about 125 and the other did over 130 in prop testing. We used clipped 9-8 Tornado nylons, and cable lines. I'd expect the right APC would do better, and solid lines would help. We had leadouts with exposed clips, etc. The second one did have a barstock aluminum circular bellcrank. Both used Harter's proto pans with single wheel gears.
Seems to me like the only "Rat" event flown these days is the "Quicky" event. "Skat Rat" was a nice design, & a CG kit. Not positive it's legal, but it should be.
