The trick I use for any weight fiberglass cloth is to thoroughly soak the cloth with resin and then steamroller it down with a roll of toilet paper. Cheap stuff works great. You will want use the direction of the roll that does not unfurl. The excess resin soaks into the TP and you peel it off and continue. Works with polyester finishing resins as well as epoxies. A second coat of resin after the first one dries will be necessary to fill the weave but you will end up with a flat surface without any wrinkles or excess resin.
Ken,
I'm glad you mentioned "Polyester Finishing Resin" because I get trolled and marginalized every time I bring up PFR.
I posted Sig's offering on Polyester Finishing Resin over at CFC Graphic's vendor's corner.
PFR is all the R/C pattern guys used for years, including myself. They taught me.
I'd apply one coat of PFR thinned 50% with acetone on the balsa, let dry to the touch then scuff up lightly. Clean extremely well.
I would then lay the dry cloth in place and apply another coat reduced where it's brushable without pulling the cloth.
After the panel was given this coat, toilet paper, unused preferred
, was spread onto the surface, pressed only to remove the excess as 'blotting.' Lift the toilet paper gently then look for areas that may be 'floating,' rub them down, but generally doesn't happen.
Here's an interesting thing. Guys would do another coat the same way for extra buildup. I would just load it up with a good grade auto primer applied wet.
Most know the rest.
No photos this time.
