  • July 22, 2025, 04:27:21 PM
Author Topic: Ok, here we are...  (Read 8865 times)
Offline Jared Hays
Re: Ok, here we are...
« Reply #50 on: January 19, 2015, 12:09:18 AM »
Maidened both 1/2 A electrics today.  The skyray was terrific just as much power as a black widow maybe a touch more.  The Hyper Viper also flew with as much power as the killer bee .049 but unfortunately the wing has a warp in it so it wanted to roll into the circle pretty bad.  No worries though, I have 2 more H/V kits so for now I just grabbed a wing out of one of the other 2 kits and it looks A okay.  So now have to wait for another nice day to give it another go.  I'm afraid to say the days of fighting reed valve .049 starting, running backward, quitting mid flight, refueling, messy clean up might be over for me lol.  It was, run lines, hook battery up, press start, fly, land, wind lines up, and put plane back in truck.  All before my dad had his plane warmed up and fueled ready for his first flight. LL~
Offline Vince Mankowski
« Reply #51 on: January 19, 2015, 03:20:50 PM »
Not exactly "stunt" but a fun project. Olde Tyme - Weasel Racer. Webra MK 2 diesel
Vince Mankowski
« Reply #52 on: January 19, 2015, 05:12:07 PM »
 That's a really cool little plane Vince. y1
Offline Gene Martine
  • Started flying 1952 (AMA 2903)
« Reply #53 on: January 21, 2015, 01:31:35 PM »
 (PE**) (PE**)
Another SV-11 PA-75 Power f~
Some fillets around the canopy, than more clear & base coat. S?P
Offline DanielGelinas
« Reply #54 on: January 21, 2015, 05:44:59 PM »
OK,
Here are my projects for winter: D>K
1- Brodak Viking which will have a fox .35
2- Brodak ARF superclown which had a warped wing and warped fuselage. I recovered the wing with new plastic after getting the warp out. Had to cut a new fuselage and now have three coats of dope on it. Next is silkspan. Also added a trippler on the front. Will have an OS FP .20 iron piston...
3- Finishing a Brodak ARC cardinal which will have an ENYA SS40
4- Sig Banchee which I moved the wing forward 2 inches. Also added 3/8 inch tripplers to the front. Adjustable tip weight box and leadouts. Finally added 4 inches to the stab elevator and changed the look of the rudder to 2015. Next is silkspan...
-Dan
« Reply #55 on: January 21, 2015, 05:47:18 PM »
Here are pictures of the banshee.
-Dan
Offline Jim Svitko
« Reply #56 on: February 01, 2015, 01:33:30 PM »
This was one of my winter projects.  It is a Time Machine 50 that had become a hangar queen.  I built it maybe ten years ago or longer, I can't remember for sure.  It did not look like this at that time.  I have no "before" photos.  Just as well since it did not look very good.  I have built several of the Time Machines and the 50 flies better than the other two sizes, at least for me.  I never liked the jet style look of the original Time Machine so every one I built had a modified fuselage: either a bubble canopy or turtle deck.  I understand that Tom Dixon has a Time Machine II version which eliminates the jet style look.  Maybe I can take credit for convincing Tom to change the look.
It became a hangar queen because I never could get the Double Star 50 to run well no matter what I tried.  And, it had a rather quickie paint job that I never really liked.  So, it just sat around, or got kicked around, acquiring hangar rash and dust because I had other projects to finish.
There were a few times the DS 50 ran well enough to show that the plane had performance potential.  So, last fall, I decided to get this thing in the air again.  I wanted it to look better and to have a reliable engine.  I sanded off all the existing color except for the orange, which was part of the original paint job.  I re-worked the engine mounts, installed an LA 46, and cut away a portion of the front bulkhead to replaced the 4.5 ounce tank with a 5 ounce tank.  I expected a weight increase due to the better finish so I wanted more fuel capacity in case I needed more nitro.  The original weighed 52 ounces, now it is 55 ounces.  The original also had a "half cowling" and a fully exposed engine.  I trashed that cowling and made a new one.
I have had time for only two flights since the re-work.  The LA pulled it around just fine but it was a cool day with low humidity.  It will not do that well in the summer.  But, for those two flights, I was using only 2.5% nitro so more nitro will help.  Also, I was flying on 0.018 x 64' lines, eye to eye.  Maybe going to 0.015 lines will help a bit or maybe shorten the 0.018 lines.
I started another Time Machine 50.  It will not be fully sheeted foam as this one.  It will have the foam/cap strip method.  Maybe I can take a few ounces off of the new one.  I am looking for a different engine for the new plane but if I have to, I will once again use an LA 46.
From a distance, the re-worked plane looks OK.  There are surface flaws and dings that I did not address as I wanted to get another plane in the fleet without taking too much time.  It was worth the effort.  It looks good enough, has a reliable engine, and should have enough performance to compete with it this year.
Online Gerald Arana
« Reply #57 on: February 01, 2015, 03:05:59 PM »
On that DS 50, sounds like the PL is in backwards. Have you taken it apart and checked it? Or looked in the exhaust?  ::)
Good luck, Jerry
Offline Jim Carter
« Reply #58 on: February 01, 2015, 03:06:34 PM »
Well, now that the SiameseMaster is completed, successfully flown and now just hanging up collecting dust, I've started a new project.  Check this out!! Can you guess what it is??
« Reply #59 on: February 01, 2015, 03:07:48 PM »
B-29 or B-50
« Reply #60 on: February 01, 2015, 03:20:37 PM »
Wow.  That's very cool.  A real model airplane.
Offline Jim Carter
« Reply #61 on: February 01, 2015, 03:42:49 PM »
B-29 or B-50
L.O.L.!! Yeah, I just noticed that It showed on the plans!!  l.o.l.!!  It's a scratchbuilt copy of an old KYO B-29 Superfortress kit that my flying buddy owns.  He didn't want to part with the kit but he allowed me to replicate all the parts and I finally got bored and started assembling the thing.  Now I have to figure out how I'm going to get my hands on 4 each reliable OS .25 r/c fsr or fx engines (I think I'll feel more comfortable with ball bearing engines).  I know I'd like to have a third line for the throttles or maybe rig the throttles for radio control.  Either way I need to scrounge some engines from somewhere so I can hopefully get to Brodak's for the first time in my life!!  Unfortunately I don't know enough about electrics to rig it and feel comfortable besides I suspect I'd have a heck of a lot more money invested ready to fly versus the glow engines, huh??
Howard, thanks for the kind words!  Hopefully it will be worthy!!  I've got great ideas but laughable skills!!   ;D
Offline Jim Svitko
« Reply #62 on: February 01, 2015, 04:47:19 PM »
Good luck, Jerry
I have two of the DS 50s and they both ran the same.  Never taken them apart except to take the heads off to add/remove shims.  All the DS engines (baffle piston) seem to behave the same:  going lean, running away, low on power, etc.  A larger venturi cured the DS 40 but the 50 did not respond as well to a larger venturi.
Offline Sean McEntee
« Reply #63 on: February 01, 2015, 04:54:15 PM »
the LA25s are very reliable and run like swiss watches.  My next winter project is a profile B-17 that will have 4 Norvel .061s and the throttles will be controled with a 2.5g radio.  Itll be allot easier to get servos working together than all of the sub-belcranks needed.
As for me and this winter, the Aeroshell T-6 is still chugging along slowly.  Work has been keeping me late alot so progress is slow.  Hoping to have the colors on it before I leave for NTC on the 9th.
I always wanted one of the late, great Byron Barker's awesome paint stands.  Alas, he is no longer with us so I had to improvise.  My building table is a big slab door that I "tactically aquired" from some old barracks being torn down on post.  The cutout for the door handle is against the wall.  Using that, I built a stand out of PVC that uses that hole to anchor it.  I can cut different size legs to raise or lower the stand to suit the needs of the model I'm painting  I can also pick it up and swing it out of the way so I can still access my table to start work on the next one :D
