I like the idea of hit counts. Amazing what we can measure now.
So castor oil film is acting as insulation, and that's what's doing the cooling. Interesting. Aren't there ceramic-coated cylinders or pistons these days? Do they do the same thing?
Howard, many of the "plasma" sleeves and pistons, are simply anodized aluminum, I would think not about the mimic oil coatings.
There are still several things going on that cools motors maybe as many as 5, it is not just coating.
It is also interesting that some's definition of "coatings" is simply turning a few ten thousands or more of aluminum into aluminum oxide
Interestingly though Scott made a ceramic head for a airplane engine, It was extremely hard to get it into a 4 cycle, you had to turn the needle out as far as possible to try to get the engine to run rich, the head was so hot inside,and so cool outside, it just wanted to scream 2 cycle
