I have used this method on planes with oil soaked noses with great success many times.
Cut the top off tin a gallon fuel can.
Fill it 3/4 with alcohol. Any kind works, rubbing, wood, or ethyl.
Dip the nose into the can repeatedly and eventually nearly all of the oil will dissolve from the wood into alcohol.
It takes a few sessions, let it dry out overnight in between.
Phil
