Hi
Personally I use Aerosynth3 which is mentioned in the other discussion.
Regards, Massimo
Hi
It is very good that Frank opened a new topic, and Randy installed it in the correct section of the forum.
I want to ask Massimo about synthetic Aerosinth 3 oil.
Where do you buy it? Or you have very large reserves.
I urgently need to buy 5 liters of Aerosinth.
I think that this is the best synthetic oil for today !!!
On this oil, all RC and CL flew German pilots for more than 10 years.
Before testing this oil for the first time I used only Motul and castor oil (5% + 11%) for my Salker 66, it was 5 years ago. After 70 - 100 flights, carbon deposits on the piston constantly appeared which strongly worsened the engine performance. The engine had to be disassembled and cleaned. Before I once again disassemble the engine for cleaning the piston and silencer, I was given an Aerosinth test. I on this oil prepared 1 liter of fuel (10 flights for 6 minutes). Oils Aerosinth - 5% and castor oil 11%. After I made 10 flights during the day, I removed the cylinder cover and saw that the piston was already almost clean. The next day I still prepared 1 liter of fuel on this oil. After flying, in the evening I completely disassembled the engine and was shocked. Neither on the piston, nor on the inner part of the cylinder cover, and most importantly - in the interior of the silencer there was not even a trace of carbon varnish deposits. The engine inside became like new.
After that, I reached this oil all season - it's about 200 - 250 flights. The engine was absolutely clean and its work was constantly equally stable both in the cold and the heat.
It's a pity that Graupner took off this synthetic oil from the sale. Graupner decided to sell only fuel on this oil.
Here is such a marketing.
May be members of our forum advise me to replace this oil or prompt a place where it can be purchased?
Regards, Ruslan
