  • July 06, 2025, 12:26:19 PM
Author Topic: Test flight on newplane  (Read 1343 times)
Offline Leo Mehl
« on: May 17, 2008, 07:38:20 PM »
Well did flight testing on new Arctic Fox and there were a few things needing fixing so am still in process of triming. Good news is the plane stays in horizontal grove both upright and inverted. Turns very well inside but needs trim for outside manevours. My engine is a little high for the tank pickup so need to lower the engine about 1/32". Lands an takes off good. Basicly is going to be good flyer after trimming. I will put this in the success column. #^ #^ #^ #^ #^ HB~>
Re: Test flight on newplane
« Reply #1 on: May 17, 2008, 08:56:47 PM »
Good news Leo!!!
Keep those other guys in line would ya?
Paul H^^
« Reply #2 on: May 18, 2008, 12:08:59 AM »
Hi Leo,
Wish the maiden flight of my new classic plane went as well. I'll be repainting for a couple of days. Sigh...
« Reply #3 on: May 18, 2008, 07:34:57 AM »
Great to hear the "Artic Fox" is  working.  Must be a lot of practice to decide only 1/32 of an inch will correct the engine run.  DOC Holliday
Offline Leo Mehl
« Reply #4 on: May 21, 2008, 10:14:57 AM »
Still working on the trimming and Doc The 1/32 inch is basicly a guesstament as usual. I will have it flyin good soon. y1 y1
Offline Leo Mehl
« Reply #5 on: May 30, 2008, 02:44:10 PM »
Doc, I was right on with the 1/32" drop of the engine Now runs the same inverted. Maybe just maybe i knew what I was doing which has been suspect for many years. All the other changes I did also worked. It could actually be luck but my ego would like to claim I knew what I was doing. S?P HB~>
Offline Leo Mehl
« Reply #6 on: May 31, 2008, 06:00:15 PM »
HI Leo. Just remember, the sub conscious does wonders if you let it. <= y1 #^ D>K
your right considering I do my best work without thinking. My best ideas come to me while sleepingor basically unconcious. My last hipmotist said that there is no whay he could reach my sub concious. It was always too active with all the crap I thionk about. Must be the dope fumes. HB~> HB~> HB~>
