My friends and I have been using Spectra lines for all our half-A airplanes, and all the weight and size advantages are very real, but what pleases me the most is the speed of fabricating a set of lines!
Takes about ten seconds to tie a Palomar knot to a line clip, and we have yet to see one fail, other than the fellow who didn't feel secure with such a simple knot, and used CA for insurance. One line failed right at the edge of the CA hardened area, as expected by some of us who stopped using the AMA method of soldering copper wire windings to insure line fatigue, many years ago.
I love Spectra, and the available high visibility colors (red and yellow from Tufline) stand out great on any field surface, paved, grass, or dirt. My favorite high visibility color is yellow, and I have it in three test strengths so far (10, 20, and 30 pound test).
Tufline by Western Filament Inc is the brand we are using, and the only problem we have found so far is the tendency for the very light stuff (10# or less) to tangle if unwound with out tension on the supply reel.
Spectra is evidently woven in tubular form, and then wound tightly on a supply reel, which flattens the tube. If allowed to unspool by itself, it will instantly curl itself into a snarl you won't believe!
Simple prevention is to hold tension on the line until unreeled, and then pre-stretch the line to about half it's test strength. This is only necessary for the very light lines, as the 20# test and up seem to be well behaved.
Hey, watch me wind up a set of Spectra lines in seconds, as opposed to many minutes for steel lines, and you will see yet another advantage of this marvelous product.
