  • July 03, 2025, 12:48:06 AM
Author Topic: Propellers for large stunt engines  (Read 1783 times)
Offline Robert Zambelli
« on: September 30, 2008, 02:39:47 PM »
Many people prefer the PA and Rojett engines for stunt.
What are some of the popular prop sized for thse engines,
from .60 up to the .90 displacements?
Offline Jim Pollock
Re: Propellers for large stunt engines
« Reply #1 on: September 30, 2008, 04:11:43 PM »
Bob,
What I was running on a ROJ .61 was a 13X3.75 flat back Brian Eather 3 blade.
I think that it would very well on the PA .61 as well. Also a 13X4.25 Bolly 3 blade cut to 12.5" would work good too.
I don't know a lot about the 75.-90 engines but I think David used a 13X4.5 3 blade on his WC plane with a PA .75.
I'm sure others will chime in here as well shortly.
Jim Pollock   H^^
Offline peabody
« Reply #2 on: September 30, 2008, 04:48:58 PM »
Check the Bolly prop chart that Randy has on his web site....
Offline Mike Greb
« Reply #3 on: September 30, 2008, 07:19:15 PM »
I run a Zinger Pro 14-5 on my RoJett76.
Offline peabody
« Reply #4 on: October 01, 2008, 06:03:42 AM »
Noel Drindak's "We have the technology" column in the currnt issue of STUNT NEWS does a great job of citing prop choices...and these choices reflect the top flyers in the Country...
« Reply #5 on: October 01, 2008, 10:12:26 PM »
      12.5-13.5" 3-blades for 60-75s, 3.5-4" of pitch.
p.s. For reference, David's 75 setup uses a 13-4 Eather 3-blade.
« Last Edit: October 03, 2008, 09:23:36 AM by Brett Buck »
Offline RC Storick
« Reply #6 on: October 02, 2008, 08:24:14 AM »
PA .75 I run a 15 inch two blade and a 13.75 X 4 three blade. If I could get a bigger 3 blade I would run it. The reason to run a bigger engine is to turn the biggest prop possible. Ask Randy Smith
