  • July 05, 2025, 01:53:02 PM
Author Topic: Plane weight  (Read 1445 times)
Offline Pat
Plane weight
« on: March 29, 2013, 09:37:26 AM »
Well I weighed my Cobra and my Olympic. This is the first time I ever weighed a plane, and after seeing so many folks on here discussing it, I figured it might be pretty important to know. The Cobra comes in at 48 Oz, and the Olympic at 46. Are these decent weights for these planes? Both will be using Evo .36's
Pat
Re: Plane weight
« Reply #1 on: March 29, 2013, 09:55:19 AM »
You are in very good shape.  I'm sure they will fly well for you.
Offline Richard Koehler
Re: Plane weight
« Reply #2 on: March 29, 2013, 09:58:26 PM »
Sounds good to me too, the EVO-36 is one strong motor!
Re: Plane weight
« Reply #3 on: March 30, 2013, 07:57:43 AM »
Those weights sound great to me.   Now if I could only match them.
Offline Pat
Re: Plane weight
« Reply #4 on: March 30, 2013, 09:45:32 AM »
John,
This is not advice, as I don't know enough about what I am doing when it comes to building these planes to offer advice, just information. The Cobra is an Umland kit, and the Olympic is from a Brodak kit. Both planes were built exactly per the instructions(I don't have any of my own "tricks" yet). So the only place I can see where I could have added much weight was in the finish. The finish was the standard 3 coats of dope on raw wood, and sanded smooth, Silkspan, three more coats of dope (thinned slightly less) and sanded, two coats of duplicolor primer(sanded almost completely off) then color(duplicolor) wetsanded with 1500 grit, and then clear coat(which has not been wet sanded or polished yet)
Pat
Re: Plane weight
« Reply #5 on: March 31, 2013, 07:10:10 AM »
And where are the pictures????    I think my Olympic was in the 50 ounce range.   Was a great flyer until wind got it coming out of the clover.
Offline Pat
Re: Plane weight
« Reply #6 on: March 31, 2013, 08:40:14 PM »
John,
 Here is my current flying stable(Olympic and Cobra), to be added is a Colossus and a Sig Magnum...
Pat
Re: Plane weight
« Reply #7 on: April 01, 2013, 05:55:29 AM »
Hey I like both of them.  They look great.
Offline Pat
Re: Plane weight
« Reply #8 on: April 01, 2013, 09:40:38 AM »
Thank you Doc!
Re: Plane weight
« Reply #9 on: April 01, 2013, 10:13:15 AM »
Hi Pat,
Those should really look good in the air!  We'll see if we can't keep the Colossus on light side of the equation. y1
BIG Bear
RNMM/AMM
Offline Balsa Butcher
  • High Desert Flier
Re: Plane weight
« Reply #10 on: April 01, 2013, 01:47:39 PM »
First the good news: Olympic looks great! Nice paint scheme and 46 ounces is definitely in the ballpark as far as weight goes. Now the bad news: Vertical stabs are on upside down. They should angle rearward from the top and be higher over the stab than under. Doncha' hate it when that happens? Now the good news again: It probably will not make a difference in the way the plane flies.  8)
« Last Edit: April 01, 2013, 02:11:26 PM by Balsa Butcher »
Pete Cunha
Sacramento CA.
AMA 57499
Re: Plane weight
« Reply #11 on: April 02, 2013, 05:56:29 AM »
What an eye.   Even after having built and competed with one I didn't notice the rudders.    To me it looks better with the rudders sitting lower.   Wish I had thought of that.
Offline Pat
Re: Plane weight
« Reply #12 on: April 02, 2013, 07:13:54 AM »
Ugggggghhhhhhhh!!!!
 I have been sitting and looking at the Olympic trying to figure out what didn't look right! Oh well, I am going to leave it as is and see how it flys. Not gonna rip things apart now.. Thanks for pointing out my short falls Butcher! Lol!!!
Y'all have a good day.
Pat
  • High Desert Flier
Re: Plane weight
« Reply #13 on: April 02, 2013, 09:09:22 PM »
One thing I forgot to mention: If you sanded the vertical stabilizers to an airfoil make sure they are shaped to generate lift toward the inside of the circle. This will cause the nose to yaw the nose to the outside. Reversed it may cause line tension problems.  8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline Pat
Re: Plane weight
« Reply #14 on: April 03, 2013, 04:05:59 PM »
Thanks for the heads up. I sanded them as per the plans, and double checked the air foil on them before mounting, I just neglected to check the side profile... Grrrr!!
Pat
