  • July 16, 2025, 02:47:17 AM
Author Topic: OS 25FP Spray Bar and Needle Valve  (Read 1933 times)
Offline Crist Rigotti
« on: June 24, 2019, 07:07:58 PM »
Anybody know where I can get a spray bar and NVA that fits an OS 25FP?
Offline James Lee
Re: OS 25FP Spray Bar and Needle Valve
« Reply #1 on: June 24, 2019, 07:14:54 PM »
the original OS NVA is no longer available.....   The alternative at this point is an RSM small ST clone nva ..   Need to drill the case for the larger spraybar.... and a slightly larger id on the venturi
Jim
Offline Brent Williams
« Reply #2 on: June 24, 2019, 08:32:52 PM »
Enya now makes a replacement OS FP/LA diameter needle valve assembly.
Offline Dennis Vander Kuur
« Reply #3 on: June 25, 2019, 08:37:50 AM »
Crist,
Let me check my "stash" and see if I have an extra. Are you looking for the remote NVA or the one through the spraybar?
Hey! I thought you were all electric now. What plane are you planning on using the FP .25 for?
Dennis
Dennis L. Vander Kuur
AMA 29292
« Reply #4 on: June 25, 2019, 09:22:35 AM »
OK guys, I found one in my stash that I hadn't gone through in years.  Thanks for all the suggestions.  Here's the back story.
I built a Jamison Special back in '02 with an OS 25FP.  I flew it VSC and then built another JS and used an OS 35FP in it.  I gave the 25FP powered to my brother like 10 or more years ago.  It hung on his wall till this Spring.  He decided to get back into CL since his teens.  He got it running and flew it for about 20 flights, you guessed it, he crashed it.  It has since been repaired and he needed a new NVA to complete the repairs.
So, no I didn't come back to using slimers again.  As a matter of fact, he's has a profile almost ready to go and yes, it is electric powered.  My brother was the one who got me interested in electric in the first place.
So now you know the rest of the story.......
« Reply #5 on: June 25, 2019, 12:27:35 PM »
Crist,
Glad to hear you found what you needed. Hoping to see you at one of the contests this summer.
Best regards,
Dennis
AMA 29292
« Reply #6 on: June 25, 2019, 08:59:03 PM »
 Glad you tracked one down Crist. After seeing this post I did some searching for one last night on Ebay. Usually have pretty good luck there but there was nothing at all. There weren't even any FP.25 Stunt engines, only R/C versions. Kinda depressing actually.  :(
« Reply #7 on: June 25, 2019, 10:16:54 PM »
Yeah, I hear ya!  Pretty soon all that will be left is electric stuff!  ;)
« Reply #8 on: June 26, 2019, 06:37:50 PM »
 That's why I'm glad I've got what's probably more than a lifetime supply of NIB FP's in various sizes.
« Reply #9 on: June 26, 2019, 11:01:08 PM »
Good for you!
Say hi to the gang for me.
Offline Allen Eshleman
« Reply #10 on: June 28, 2019, 08:20:11 PM »
I recently bought one of the Enya variety from Shtterman on Ebay.  My FP25 works wonderful with it.
« Reply #11 on: June 28, 2019, 08:39:51 PM »
Thanks.  I saved this seller.
