  • July 15, 2025, 09:08:55 PM
Author Topic: Off Topic  (Read 2358 times)
Offline Colin McRae
  • Are we having fun yet??
Off Topic
« on: March 06, 2025, 06:47:03 PM »
Just heard on the news that today's SpaceX rocket launch 'rapidly disassembled' shortly after takeoff.
Boy, I'm sure glad it didn't 'blow up'  ;D
Offline Steve Berry
Re: Off Topic
« Reply #1 on: March 06, 2025, 06:49:24 PM »
It was doing OK until it got to the 3rd corner of the hourglass...wings folded and it augured in. No pattern points, but did get style points for the crash.
Sent from my SM-N986U using Tapatalk
Offline Colin McRae
Re: Off Topic
« Reply #2 on: March 06, 2025, 06:51:27 PM »
crash.
Not crash. Rapid disassembly!
Re: Off Topic
« Reply #3 on: March 06, 2025, 07:23:00 PM »
Big Jim McBob and Billy Sol Hurok were unavailable for comment.
Re: Off Topic
« Reply #4 on: March 06, 2025, 08:16:37 PM »
  Rapid UNPLANNED Disassembly !! But like they say in gymnastics, they "stuck the landing' of the booster!!
Offline Colin McRae
Re: Off Topic
« Reply #5 on: March 06, 2025, 08:29:46 PM »
I stand corrected. Rapid Unplanned Disassembly
I'm still glad it didn't blow up!
Re: Off Topic
« Reply #6 on: March 06, 2025, 10:14:55 PM »
 Also known as "when the internals become external".   :)
Offline Jim Svitko
Re: Off Topic
« Reply #7 on: March 07, 2025, 06:28:49 AM »
The booster made it back home.  Now I hear something about it going out of control, tumbling.  If that is true, nobody knows if that caused the explosion or if the someone hit the destruct button.  Isn't this the second failure of this rocket?  One other exploded as well, not too long ago?
Re: Off Topic
« Reply #8 on: March 07, 2025, 02:59:32 PM »
   It is not the second failure, I think this is 8th or 9th failure, that is, 100% failure rate so far. They claim they were following the German idea of designing via test and/or replacing reliability analysis with flight statistical data. I also note that a lot of the fanboi coverage is centered on booster landings rather than successful flights, so the fact that is has routinely failed is of little consequence. We'll see if the FAA considers it relevant or not.
Offline Jim Svitko
Re: Off Topic
« Reply #9 on: March 07, 2025, 03:27:34 PM »
Design via test.  That might work for something that stays on the ground.  You can look at things and maybe have a clue as to what happened.  But, I would think it rather difficult to determine what is going wrong when all you have left to analyze is flight telemetry data and a billion pieces scattered all over parts of the earth.
Re: Off Topic
« Reply #10 on: March 07, 2025, 04:53:28 PM »
  I think you have discovered the flaw in the plan.
    There is a legitimate argument to be made between how much effort you put in to ground analysis and test, VS flight test, *as long as you take maximum advantage of the flight test, and as you say, you instrument it sufficiently to be able to diagnose it*. I am no insider for SpaceX but it has been my take-away that they are just cranking them out, and maybe *not* actually feeding back their results to the next launch - in fact that they are flying so quickly that the feedback only applies to 3-4 back in the line, because there are always 1-2 "completed" and ready to prep/launch. So the next few are likely to have the same defect that killed the current one, maybe it is marginal or 50/50 to make it, that's legitimate. But maybe it is 75% likely failure and that is very likely to fail again on the next two flights. Launching them and having a repeated failure makes nearly no sense.
    Realistically they are under zero flight pressure, there is no pressing schedule since there are no customers and there is no national security programs involved*.
   I don't work there, I don't know for sure, I could easily be wrong, maybe the failures are from different causes, and they are fixing them one at a time. But the last two look like exact replicas of each other.
*several times, I have been around or involved in missions where there was a failure of some sort, and there actually was a pressing national security requirement, so they took their chances. The most notable was after first the Challenger failure, followed a month later by a Titan 34D failure. In that case there was a Vandenburg shuttle launch in a few months, and it had a national security payload. So there was a plan (that got pretty far along) to go ahead and launch it with a minimal crew in case it failed again. In the event, it obviously didn't happen, Reagan told them no more launches unless they figured it out.
  An example that did work out was Apollo 4 and 6. These were test flights for the Saturn V. 4 worked very well, textbook. 6 had multiple failures in the second and third stages, and not in the same subsystem, and had 2 engine shut down on the second stage. But they had enough telemetry and did enough analysis and ground test that they were confident enough for the next launch to put 3 guys in it and send it around the moo. That one worked perfectly. In that care there was *enormous* schedule pressure and nearly unlimited funds and resources available to pay for very extensive analysis and ground test.
Re: Off Topic
« Reply #11 on: March 07, 2025, 05:22:13 PM »
Hmmm.  Kinda cool to have this "hands on jay at our beck and call for these "otherworldly" events ain't it!
Thanks Mr. B!
Ted
Offline RC Storick
Re: Off Topic
« Reply #12 on: March 07, 2025, 05:29:03 PM »
 A Machine that complicated is bound to have issues when under development. Look, Windows updates can't get it right. Then think of how many internal combustion engines failed before they could make them last 100000 miles. They will get it right, I am sure.
Offline Jim Svitko
Re: Off Topic
« Reply #13 on: March 07, 2025, 05:40:14 PM »
I was watching the evening news.  Elon called this incident a minor setback.  What does it take to be a major setback?
They might get it right, one day.  The issue is, as I see it, unless the cause(s) of these failures is/are identified, it is a crapshoot.  The next launch might work perfectly, but if nothing was changed, no specific problem identified, it would be very risky to announce that you have solved the problem.  Have I missed something here?
Re: Off Topic
« Reply #14 on: March 07, 2025, 05:42:58 PM »
  No.
Re: Off Topic
« Reply #15 on: March 07, 2025, 07:54:12 PM »
 With pockets that deep losing one of these rockets is, maybe, a rough equivalent to one of us burning out a glow plug.  D>K
