I put the prop so its flat , agaisnt compression , almost . Itll go a bit more with airload against comp . Depending on how clapped out . for a TIMBER PROP .
this way if the earth is on top off the aeroplane , when it lands , if its fairly smooth , it should be o.k.
TWO Props , a TWIN . ! Inner Flat - Outer vertical . If you put BOTH at Full Compession T.D.C. its opposite ? So you flick UP on the inner so you dont get blood on the aeroplane
flicking ACROSS into the Outer . Tho theres sometimes a fuselage in the way . that can hurt too .
BUT , if the two props are at 90 degress , the V I B R A T I O N seems somehow to Not Get Cumulative , as it offten does with BOTH indexed the same !
Most people ' reverse ' bump start these days . Though. Prop Fwd. against compression, after checking for ' bump ' ( ign ) the belt backward across the slack , so it hits Rev. Comp. and BACKFIRES FORWARD ,
and shees running .
For a unbalanced prop ( blade ) and a vibratory engine , put it at T D C . the counterweights then opposite the cylinder . put the HEAVY Blade opposite the cylinder too ( in synch with the crank counter weight .
THIS gets lesss ' rock ' as its less angular unbalance , and theres not twelve cylinders to even it out .
