  • June 18, 2025, 08:48:37 PM
Author Topic: retainers for lines  (Read 2924 times)
Offline Bootlegger
retainers for lines
« on: October 01, 2020, 04:11:23 PM »
  Guy's I am looking for some line retainers that are used on the sig line reels.  They appear to be about1/2" wide and go from side to side, to keep the lines on the spool, any help will be 'ppreciated..
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Reptoid
Re: retainers for lines
« Reply #1 on: October 01, 2020, 04:44:36 PM »
Melvin Schutte at MBS     3025 Line Reel Clip - 2 ea. 1.50
http://mbsmodelsupply.com/Catalog.pdf
Lots of line related goodies. Good people, good prices, good service.
       Don
       AMA # 3882
« Reply #2 on: October 01, 2020, 05:23:17 PM »
Bend up your own from metal strapping scrap.  Easy to do.  y1 Steve
Offline Phil Spillman
« Reply #3 on: October 01, 2020, 06:37:11 PM »
Brodak's sells them too! Check out their web site FlyIn@Brodak.com.
Phil Spillman
Phil Spillman
Offline RogerGreene
« Reply #4 on: October 01, 2020, 08:27:37 PM »
I make my own lines reel. I use velco dots and velco straps to keep the lines tight on the reel.
Roger
Fly Stunt <><
AMA 435R
USAF Veteran 1962-66 SAC
Life is 10% what happens to you and 90% of how you react to it. FAA #FA3RFLPAN7
« Reply #5 on: October 01, 2020, 09:29:13 PM »
I was looking for these, too, for the big reel.  Every response to this question was good.  Thanks, guys.
« Reply #6 on: October 01, 2020, 09:34:02 PM »
    And obviously, SIG sells them separately also, for both widths of line reels.
Offline Perry Rose
« Reply #7 on: October 02, 2020, 05:08:56 AM »
A #64 rubber band and a piece of a flip flop.
Offline Bootlegger
« Reply #8 on: October 02, 2020, 08:53:03 AM »
 First thanks to everybody for your replies, Dan I tried Sig and was told that they would call back, but they haven't   yet, will try again...
    Thanks again one, Bubba
Gil Causey
AMA# 6964
Offline Steve Tomlinson
« Reply #9 on: October 02, 2020, 09:41:07 AM »
Sullivan sellows the reel and clip for $5.14    cant beat that and no hassle of "building" a simple reel!    http://sullivanproducts.com/product-category/control-line/page/2/
STEVE Tomlinson
« Reply #10 on: October 02, 2020, 10:54:47 AM »
Lost count of how many line sets that the clip was too hard to remove or even put on the reel.  So I in my miserly way drill holes through the side of the reels.  A piece of wire through the line clips and the other end threaded through hole in reel.  Loop wire through hole several times.   So far have never had a set of lines come loose on the reel. D>K
« Reply #11 on: October 02, 2020, 11:05:02 AM »
I have found the best source has been to use a metal detector in the pit area of a contest after it is over. LL~
Seriously, I have gone to the rubber band already mentioned.
Offline Bootlegger
« Reply #12 on: October 03, 2020, 07:40:01 AM »
    H^^   Guy's I found some, and have them on order.  Thanks to everybody   D>K
Gil Causey
AMA# 6964
Online 944_Jim
« Reply #13 on: October 04, 2020, 11:51:47 AM »
Mr. Roger,
Can you described be your construction method? It appears to be PVC pipe and plexiglass sheet.
TIA,
Jim in MS
