Just a minor note of correction, and a little Stunt History.
I drew the plans for the Legacy. It was an challenging task, that some may find interesting. It was about the turn of the century. John Brodak called and asked me to help Allen Brickhaus design a replacement for his Buccaneer. It had been produced by a kit maker in Texas for a number of years. This company had recently dropped Control line models from their lineup, opting to produce only RC kits. When Allen asked for the rights to the design back, since they were not producing it any longer, they refused. That's when he and John B. determined to create a new design replacement. Since I live in Utah, and my friend, Allen lived in Illinois, this project was totally accomplished over several (many) calls over the telephone,. I can tell you that the airfoil used is an NACA 0018 4 digit foil, used in Compufoil's program and using Allen's numbers for Span, Chords, and Areas for wing and flaps etc.
After the design work was finished, Allen built the prototype and the files were sent to Brodak to begin manufacturing, Allen contacted me and asked if I would send the files to Watt Moore as he wanted to reduce them and make a 40 sized version, so I sent the files off at his request.
Since the larger, and smaller Legacy versions come from the same CAD file, They both use the same airfoil, and are proportionate in their numbers. Bob may have used the same numbers, or perhaps Allen may have, but then that wouldn't be the first time such a thing happened, either purposely, or accidentally. In any case, it's good to see Allen's-Bob's Wing being used and enjoyed. It's a good wing and would be great for original, and many other stunt designs. Look at the time that could be saved by ordering a Legacy, or Legacy 40 wing kit? Yes, and the rest is stunt history.
BTW, That's a nice looking Genesis, but I'm looking forward to the wing mounted gear version.
