  • June 21, 2025, 04:00:32 PM
Author Topic: NVA OS max 15 LA  (Read 1380 times)
Offline John Rist
NVA OS max 15 LA
« on: August 01, 2016, 12:00:03 PM »
Just scored an OS Max 15 LA RC on eBay. Does anyone know if the NVA for an OS MAX 15 FP-S, (in stock at Tower) will fit the MAX 15 LA RC.  Or what is a good choice of a NVA for the 15 LA?  I plan to get rid of the remote needle and RC carburetor.
Offline Dennis Moritz
NVA OS max 15 LA
« Reply #1 on: August 01, 2016, 12:50:23 PM »
Yes. I've used them many times. It's necked down. Probably same diameter as LA15 CL spigot.
Offline John Rist
Re: NVA OS max 15 LA
« Reply #2 on: August 04, 2016, 03:05:58 PM »
To answer my own question - Yes.   The LA 15 RC I scored on eBay came in today.  I have an OS Max 15FP-S on hand.  The NVA and venturi from the FP fits the LA.  The only problem left is the stupid plastic back plate with the needle mounted on it.  Not sure what to do with this.  May just saw off the NVA ???
Online Motorman
« Reply #3 on: August 04, 2016, 03:25:34 PM »
Yes, just saw off the NVA from the back plate.
« Reply #4 on: August 04, 2016, 05:22:29 PM »
Or leave it. As a curiosity.
Offline Dane Martin
  • heli pilot BHOR
« Reply #5 on: August 04, 2016, 05:32:29 PM »
You can also leave it and just order the spray bar for the la-15. Pretty cheap set up
Spray bar
OSMG7324
Venturi
OSMG9251
NVA OS max 15 LA
« Reply #6 on: August 04, 2016, 07:00:43 PM »
Ahh remote needle. They work with that spigot. A bit more difficult to flush. I had one way back that I couldn't clear. Through the Venturi needle solved that. On an La25.
Offline John Rist
« Reply #7 on: August 04, 2016, 10:09:51 PM »
Spray bar
OSMG7324
Venturi
OSMG9251
I have the standard FP NVA on order.  I don't like remote NVAs.  I will just saw off the old NVA.  Haven't run this eBay special yet.  It feels good and looks OK but the proof will be in the test run. y1
