  • July 07, 2025, 11:34:43 AM
Author Topic: Butyrate Colored Dope  (Read 1240 times)
Mike Griffin
« on: November 15, 2014, 06:45:13 PM »
Where do you buy your colored butyrate dope?
Re: Butyrate Colored Dope
« Reply #1 on: November 15, 2014, 08:26:13 PM »
I get Randolph dope from a dealer near my home in Fort Worth. There is a dealer in Estherwood, LA but I don't know how far away from your home he is. Landry Aero  800-280-2884 or 337-783-7366. I have had very good results with all their products, clear and colored.
Don
Offline billbyles
« Reply #2 on: November 15, 2014, 08:28:42 PM »
I buy Randolph colored butyrate dope from Aircraft Spruce.  Randolph has a huge selection of colors and is priced pretty reasonably compared to butyrate made specifically for models.  The most fuel resistant butyrate dope I have found is Sig Light Coat, Randolph is next, and Certified is next.  I use Sig Light Coat butyrate clear for the final clear coats but I use Randolph dope for colors because of their huge selection of colors.
Bill Byles
AMA 20913
So. Cal.
Offline RC Storick
« Reply #3 on: November 16, 2014, 01:20:48 AM »
Online Howard Rush
« Reply #4 on: November 16, 2014, 01:48:19 AM »
I use dope in unmarked cans given out by Spencer Aircraft at our Puyallup contest.  It might be Randolph.  I got some blue and some white.  I had to bum some black from Dave Pellerin to make gray.
Hope this helps.
Mike Griffin
« Reply #5 on: November 16, 2014, 08:35:36 AM »
All of this helps.  Thanks go all for the information.
« Reply #6 on: November 16, 2014, 10:49:46 AM »
Unless I'm painting my house, my colored butyrate needs are typically small.  Colors cover well, so one or two sprayed coats is all I need on a new plane.  That would typically be about 4 oz.
Therefore, I buy colors in pints, or sometimes in 4 oz. bottles.  All this is Brodak...because it is readily available and is also a pretty good product.
I use much more clear butyrate, which I get from Aircraft Spruce, 2 gallons per order.  Thinner comes from  a local industrial paint supplier as PPG Acrylic Lacquer thinner.
