General control line discussion => Open Forum => Topic started by: Bootlegger on November 15, 2013, 10:21:55 AM
Title: ...Nudder question...
Post by: Bootlegger on November 15, 2013, 10:21:55 AM
  I am thinking about a piece of flat steel about 1/2" thick 6"wide and about 12"-15" long for a weight for a stooge.
  Any and all suggestions will be greatly appreciated...
Title: Re: ...Nudder question...
Post by: Tim Wescott on November 15, 2013, 11:23:45 AM
My stooges are pieces of 3/8" plywood about 18" x 30", they work fine on grass without slipping and without extra weight or stakes.
BUT that's with a 52 ounce plane with an LA-46 running correctly.  If I adjust that same engine lean on that plane, it starts dragging the stooge.
If you're on pavement then use a weight, and put something on the bottom to enhance friction.
Post by: Larry Fruits on November 15, 2013, 06:06:37 PM
The stooge I purchased from Tom Morris measures 1/2 x 9 x 14, (steel plate), and has an anti skid fabric stuck to the bottom. Absolutely no troubles at all holding my SV 12 with PA 65, either on grass or pavement.
 Larry
Post by: Randy Cuberly on November 16, 2013, 12:30:13 AM
Your steel plate weighs between 10 and 12.75 Lbs...personally I would prefer one that weighs about 20 lbs...a 6 inch by 24 inch plate 1/2 in thick would give you 20 3/4 lbs...better I think!
Randy cuberly
Post by: 55chevr on November 16, 2013, 04:54:28 AM
If the issue is that you are flying off pavement, you could use 3" Tapcons ... you would need a rechargeable drill.  A lot better than dragging a steel plate around.
Post by: rich gorrill on November 16, 2013, 05:45:27 AM
I modeled my stooge after the onebrodak sells. I attached it to a 16" x 16" piece of plywood, holes at each corner. I use 6" spikes to hold it in the ground. It works great. I don't fly off blacktop. Most people will get up set if you pound stakes into their parking lot plus how do you get them back out?
Post by: 55chevr on November 16, 2013, 06:30:16 AM
Tapcons go in with a hex driver on a drill.  Really just big hex head dry wall screws. When you are done you back them out. Next time you go there you won't be able to find the holes.
Post by: Perry Rose on November 16, 2013, 06:57:38 AM
I thought it said Tampons there for a minute.What a mind picture that was.
